Hi all,
I've a wee problem that I've been unable to sort so am now looking for some advice. For a number of weeks my drivers side headlight has been super dull and the main beam won't work. When the problem first started, it seemed temporary as occasionally when I switched the headlights on, if I switched to full beam the light would work properly and continue to to do so even when the main beam was off. Now though it refuses to work and when the headlights are on, it's less bright that the little side light. I've changed the bulb, hunted for and repaired a couple of small wires on the loom/s behind the light that were corroded but sadly still no solution and the light remains dull.
Before I take it to an auto electrician (anyone recommended around the Glasgow area?) I thought it worth a post to see if anyone else has experienced a similar problem and found a cure. Any pointers greatly appreciated.
Ryan
Ryan
