Someone else gave local dealer prices further up in the thread
I could do with a set of 4 if anyone has any.
I just tried dropping my NSR and there was a breaking noise and the window has dropped.
Sooner the better really, providing they're reasonably priced.
Failing that it will be front two now and rears later.
Huge thanks to Jon...
I changed mine and it made very little difference to the speed the windows went down/up.
So I decided to remove the mechanism and give it a service. Removing the 21year old grease from the quadrant gearbox and adding some fresh grease + 'polishing' the gears shaft and regressing it now means the windows go down and up faster than a whore's knickers![]()
It is a simple enough task.....Is there anything complicated in removing the mechanism? Is is worth producing a 'sticky'?
When I replaced the rubbers I had some improvement on a couple of the windows, but less so on the other two. Sounds like you have found the real cause. Is there anything complicated in removing the mechanism? Is is worth producing a 'sticky'?
I can still get them when I next order some parts yes but I don't 'stock' them. Best to PM me if you want to arrange somethingJon W - are these rubbers still available?
I can still get them when I next order some parts yes but I don't 'stock' them. Best to PM me if you want to arrange something![]()
I found the same. Some windows were little different and also had new motors as well. But when I had the tinting done last month, they cleaned all the mechanism out as part of the fitting and put the new rubbers in whilst they were at it. Wow. That really does do the trick doesn't it. Getting the registers out isn't hard but it's a bit of a dirty job. Gloves are a good idea.
Hi, whats the price for one door, and for whole set? Thanks
