I may have found a 100 series, any thoughts?
warrenpfo
I think I may have found a car worth looking into but thought I would post the conversation I have had with the owner and ask for any thoughts. Best start at the bottom.
The one thing that had popped into my mind was that if I made a cheeky offer of £12000 and he accepted its still £2K over what I would like to spend which could be spent on Bullbar/winch/rack etc..
Anyway happy reading and any comments welcome.
On 28 September 2010 09:40, John Glen wrote:
Hi Warren
I haven't used Overland Cruisers - I use Osaka Toyota, Coomassie St , Newport, NP20 2JP - 01633 223670. They are independent Toyota trained mechanics - they used to work for the Toyota main dealer here in Newport but set up on their own about six years ago. They have all the diagnostic kit, use OEM parts, they're far better price wise and don't do unnecessary work. Give them a ring and speak to Cal if you want more info - he knows this car.
MOT expires 18/08/2011
Tax expires 31/08/2011 (registered 01/03/2003 and falls in the current £245 band)
4 new tyres (Dunlop GrandTrek) fitted 19/08/09 @ 89,673 miles
Last full service 26/04/10 @ 99,846 miles (all fluids I stated before, brake fluid also changed, advisory on front pads that have now been done)
Last work done 20/08/2010 @ 101,972 miles (air con fixed, steering rake motor, front pads)
Two advises - will need rear discs/pads at next service and drivers side calliper inner piston boot seal has a split.
Current mileage is 102, 450
It had the 4speed Auto box, sat nav, privacy glass, rear parking sensors, dual electric tow pack, full set of MudMats and a bootliner.
Hasn't been used for off roading.
The only common fault I haven't dealt with is the drivers side front fog lights is "fogged".
I haven't any other pics and its raining here this morning (not unusual for Wales!). Happy for an independent inspection if Overland Cruisers can do it "while I wait", you pay for the inspection, contribute to fuel costs and I can have a copy if you don't buy the car. It's about a 100 mile round trip - or you could speak to/use Osaka here in Newport. The Ryder Cup is being hosted here this week, so it will be a bit gridlocked - I can do any day accept Tuesday next week.
I've attached the Glasses guide valuation I did in August 2010 at 102,500 miles. If you want to make a without prejudice offer now, bear in mind the history and the common faults that have been dealt with, and the current prices on the likes of Autotrader.
My reason for selling - don't need a car of this size anymore, sold the caravan and not planning on getting another. I tend to do the running around in my partners bland Vauxhall Zafira - better on fuel and easier to park (for her!). I've had a few test drives in the Subaru Outback and am considering the 3.0Rn - I like 4WD and a bit of ground clearance but don't need a full blown SUV.
Regards
John
On 27/09/2010 14:07, Warren Pfotenhauer wrote:
Many thanks John it sounds like you have looked after her.
It would not have been Julian at Overland Cruisers in Upper Eggleton would it as he is regarded as the Oracle of Landcruisers in that area.
As I don’t want to waste your time and mine would you happen to have any other pictures you could send me and what is the reason for wanting to get rid of her.
I cant seem to find the advert again and so cant remember if there was any MOT and Tax left on the vehicle and what you where asking for.
Would you object if it got to the point where we agreed on a price if it was subject to an independent inspection at Overland Cruisers.
www.overland-cruisers....scouk.aspx
Regards
Warren
On 26 September 2010 22:38, John Glen wrote:
Hi Warren
Sounds like you know your stuff!
My LC is an 03, 4.2 VX just coming up to 102,500.
Full service history - main dealer or Toyota specialist - all OEM parts fitted. I don't have the book to hand, but it was last serviced around 99K - including AHC, Transmission, Transfer and Diff fluids. Timing belt changed around 80K.
Steering rake motor - in/out failed and changed about six weeks ago!
AHC and Comfort Settings are both ok.
No shudder on brakes - new front pads six weeks ago
All windows lower/raise ok.
Aircon - had the problem - fixed and now all OK
Diff locks - only used once this year and worked ok
I have towed a 1500 KG caravan approx 1,500 miles.
I'm in Newport, South Wales. Approx 2hrs drive from West London.
Regards
John
On 26/09/2010 19:09, Warren Pfotenhauer wrote:
John
I appreciate your candour and no I am not a trader nor am I a canvasser just a 32 years old South African looking for a solid car to export back when he return in 2012.
In a nut shell I am looking for an 02/03 4.2l VX Diesel Auto around 100 000 miles with a good service history in good condition outside and in.
I know what I want and am very thorough in my inspection as the VX suffers from steering column adjustment motor fail which is prompted by a squealing motor on movement of the column. The auto height control also fails as the air bags go around 100 000 miles and cost £900 to replace. The vehicle needs to raise and lower quickly with a noticeable difference in sport and normal in suspension.
The under carriage needs to be free of rust as the salt on the roads has proved to not be a good thing for landcruisers especially at the rear. Abrupt braking should not have any shudder and the diff locks need to both engage and disengage as they have a tendency to seize.
All the windows need to raise and lower as the drivers side also has a tendency to fail along with the rear air conditioning as the pipes going to the rear AC unit corrode.
Sorry for all the comments but if i am taking it to SA I don’t want it to let me down.
In the one picture you have posted it has a caravan behind it. Has it done a lot of towing?
Regards
Warren
p.s I am Based in West London where about are you?
Yes - as long as your not a trader or canvasser
On 26/09/2010 15:46, warrenpfo @ gmail.com wrote:
This email was sent in response to the following advert:
102k Miles. Full Service History. Recent service. Tow Bar & Electrics. All the usual spec. Private Sale - owned and registered by me - no canvassers. £14950
Warren
Sounds like a good option, taking it to Julian would be a a very good idea
You have covered the AHC suspension stuff, the only thing I could add is to ask when the fluid was last changed, however it can still be a pain in the arse. General consensus is to change it out for something like the Old Man Emu kit for worry free long term ownership
The other thing to watch for is the Torque converter, there are a couple of threads on what happens to it in the 100 section on here
If he has fitted Dunflops he certainly hasn't off roaded it unless he is very brave.
I wouldn't worry too much about the towing. My 80 spent two years towing a double horse box with two horses and when I got it I towed a huge caravan for a few years. If this did anything at all it just accelerated the time it took to change the suspension to OME which I did at around 125000.
I would go with taking it to Julian and think about the OME kit.
What do you plan on doing with the vehicle back in SA?
You might want to look into the cost of some of the mods/upgrades, you plan on doing, here in the UK. Some things are better priced here than back home. Tyres for example tend to be cheaper here as does suspension upgrades like OME. Exhausts tend to be a lot more expensive though due to labour costs being a hell of a lot higher here than SA. Just a few things to consider while you are here.
Thanks for the points. Do you think an offer at £12000 is too little or too much. Considering you can get an 02 with 95000 on the clock for £11950 on autotradre.
The torque converter from what i know is a convern on those cars pre 2000 so far as i can tell.
Any other points/tips welcome.
Ryan
Many thanks for the reply. I plan on moving back to SA after 10 years in the UK with the wife and hence why I want to get a Landcruiser now as I have to own it for 1 year before I can import it to SA.
I will look at doing a lot of the mods here as you mentioned one of them I was keen to do was fir an ARB bull bar but the one I want is not legal here in the UK due to health and safety not that a pedestrian would be any better off if hit by a Landcruiser with or with out a bull bar I would think.
Looking for a winch, suspension upgrade possibly a snorkel, fridge, duel battery, overland RR, rear door spare wheel carrier, Long-range tank etc.
Lots of toys.
Are you dead set on the diesel? The Petrol V8's are so well priced here. You should be able to find a decent lowish mileage one for a lot less than the diesel. Petrols also tend to be less abused and not used for towing as much. Petrol price is not too bad back home from what i have heard.
You might want to double check on the bumper, i think there may even be a thread on here regarding the legality of ARB style bumpers. Not sure how companies can sell them if they aren't legal :?: . It might be a grey area. If they are cheaper here you could always buy one and fit it just before you ship it.
It might also be worth, though it will take some self control :twisted: , doing the mods as late as you can. They tend to drive your insurance premiums up considerably.
UK health and safety is rediculous! I work in construction and you wont believe the crap we go through just to be able to carry out simple tasks. :roll:
