Hi Guys
Julian said:
>the pump runs it will slow the engine down, but the engine should increase
>the revs to compensate - if it isn't then you need to check the settings - I
When my AC kicks in the revs go down but the engine doesn't seam to compensate it.
Before the fitment of the pusher pump and on steep slopes sometimes idle revs went
as low as aprox 500 rpm. Now with the walbro one doesn't have the feeling that the
engine is about to shut off. How serious can this be?
If I remember correctly the FSM procedure is not as easy as turn on a screw like
when adjusting idle speed.
I'll check it out tonight and probably have even more doubts tomorrow.
Does someone actually did this adjustment and can advise about it?
Regards
Joaquim
94 1HD-T Portugal
Chegou o Clix Turbo ADSL a 16 Megas
Internet + Telefone sem assinatura telef?nica
Saiba mais em http://adsl.clix.pt
Regards
Joaquim
94 1HD-T Portugal
