Ecoman
- Sep 8, 2010
Am I likely to have a viscous coupling on my 80? Where abouts is it? and what is its purpose? The reason I ask is that after some reading of various forums I seem to get conflicting information. Some say do away with it as its a waste of time and some swear by it and say its an excellent addition. The reason I ask is that the general consensus when they go wrong is a vibration or wobble and as you will probably have guesses my 80 has assumed a wobble!
The wobble at slow speed is almost like a tyre is out of true or a wheel is buckled but increase the revs and pick up speed and the wobble fades away. I have had the tyres checked and balanced and nothing is out of true. I have also had the 80 up on a ramp and checked the hubs while in drive and there is nothing loose or buckled. However, the wobble turns into a shudder when creeping along in gear at walking pace (stuck in traffic). It first became apparent when I had the injectors cleaned and the fuel system overhauled. With the increase of power came this shudder/wobble. I thought at first it may have been a cylinder or two low on compression but it seems that all the bores are spot on. When you take the transmission out of drive the shudder stops. Put it back in drive and the shudder returns. Again increase the power and the shudder becomes a wobble again and fades away.
Any help would be greatly appreciated
