thelal
- Mar 11, 2010
Did 4 hour easy drive on Sat and felt very slight tremor on right turns. No other issues. Thought maybe front bearing on front right was loose again and maybe need to tighten up (had to tighten 5k ir 2 months ago and don't do a lot of driving, no offroad atm)
Was due an oil change and some other maintaince checks.
Jacked up wheel and solid on bearing check. Strange give on in/out - maybe steering loose. Sat in front of tyre and definite looseness left and right.
Checked underneath and one of knuckle studs was gone and others loose.
Yikes !!!
Normally check these every time under there but mostly just visual.
Not sure how it dropped out or how long ago. Found a bolt that fitted tread pattern and tightened up other 3. Did test drive and ok. Checked again and ok
Have proper knuckle bolts and will need to fix next week. Mud seems to indicate 20-40lbs of torque with 71lbs for nut. Also disagreement on locktite.
Anyone done this?
Can I clean out (dripping lower steering arm) from below and put in stud (tighten via torx), put arm back up (with gentle tapping ensuring all 4 inline), then torque all four in sequence
WITHOUT having to do a full knuckle strip n clean Etc.
Would keep doing continual checking until full rebuild time
Yikes !!!
Anyone done this?
