Landcruiser cl5 d4d 2005.
mark1971
Hi,
Bought landcruiser 2005 new had no problems till now.
First problem is the rear suspension is stuck in the high position even tho the hight control is reading in the n position.
If i select high or low it doesnt move, car is bouncing around when i drive.
Also the heating stopes working when the car stops moving.
would be very grateful for any advise.
Thanks Mark
Rear height sensors are shot or need cleaning - the car goes into 'high' when that happens. Could be expensive if they need replacing. Milners stock them as does Simon at Toyota.
Can't help with the hearing but that's clearly not right!
I had the same heater problem, only really resolved the issue when I changed the water pump.
I had Mr T use his vacuum system to get the air out of the cooling system first and it made a little difference.
In the process I found I had a evidence of a weep on the water pump, but suspected that it was sucking air into the system so I just replaced the water pump and the problem was fixed.
