AndyCook
I have never really been happy with the sharpness of my collies brakes
running EBC discs and greenstuff pads
the pistons are free, I can activate the ABS on a dry road if i really mash the brake pedal hard
but they dont have the sharpness i have with my other cars - subaru foresters and yaris
Yesterday I put brake pipe clamps on the 2 front brake flexy pipes
then (engine off) pressed brake pedal - it was rock solid straight away
so i think master cylinder is OK,
but unclamp either of the flexy hoses leading to the front calipers and there is mushyness when you press the brake pedal initially
i clamped them and opened bleed valve and pushed the pistons in, but not all the way home and some dirtier brake fluid came out and possibly some air.
but i am sure i did this before, and still didnt get the brakes sharp.
i wonder is air gets trapped in the bottom of the caliper, where internal chambers link the calipers
i will try again pushing the pistons completely home (again with hose clamped and bleed valve open to try and expell air
i have been bleeding using both gravity and 2-person method, and also tried a vacuume system (but that often just sucks airs in via bleed nipped threads - even with grease used to try and seal them)
how is the brake performance in your collies?
anything else i can try?
