OK I've finally managed to make some time to update the thread.
I'm now technically working the least amount of hours I've ever done, work wise. But then factor in gym, working on LJ, working on Michaels house, going on trips, nights out in the city and suddenly I havnt got much time at all.
Anyway back to 4wd's.
So I said I would get some more pics of the super rare Suzuki LJ50. So this is Suzuki's first 4x4 and is powered by a 600cc 2 stroke engine.
I mentioned that it had got some great features, that at the time 40+ years ago were quite innovative.
One feature was all the electrics were on top of the engine to keep them nice and dry.
Something that I've never seen before but is an awesome idea is the 2 hoses that go from the heater inside the car into the distributor. So the distributor is permanently pressurised with warm air. Perfect for keeping the engine running when fording rivers.
We've done a bit of work on the little Suzuki and now its going back into storage.
Basic, retro interior.
Its got little chrome lift up bars, presumably for when driving with the doors off.
Anyway back to LJ.....................................
So Friday night I picked the freshly built diff up from my diff guy.
A smear of blue RTV sealant.
Its heavy but it went in a lot easier than I was expecting, once I'd maneuvered myself into a position where I could bench press it up and into position.
Air line connected.
2 of the rubber boots on my track rod ends were split, yet the ball joints felt good.
Replacement rubber boots.
I removed the old boot, cleaned all the old grease out and then filled the ball joints back up with some of the marine grease I'd bought for the wheel bearings and king pin bearings.
1 done.
Other one.
Back onto the front axle rebuild.................
The next job was replacing the inner oil seals.
These are the better than genuine Toyota (supposedly) Trail Gear oil seals.
Old oil seal out.
I then discovered that the new oil seals were a different size to the ones needed for LJ.
One good thing about Landrovers......................The swivel balls unbolt from the axle, meaning they can be replaced.
The ones on LJ were quite worn and pitted in places, but obviously the only way to replace them would be to cut them off and weld new ones on. Not something I want to do.
After realizing the oil seals were wrong I was keen to see if the new ball swivel seals would fit and work.
NO wrong ones.
After speaking to Dave (Model maker man) Who has also bought the same bits and was in fact the persons who inspired me to buy these bits, the thought was that the metal
rock rings should still bolt up, especially if the bottom/top 2 holes are enlarged slightly.
I figured even if I couldn't use the rock rings I could still use the ball seals, with my old Toyota metal plates.
So I fitted the rubber seals.
Hub on.
Holes enlarged and rings bolted onto the other hub.
I found the rubber seals were a really tight fit over the ball. I managed to bolt one of the rings on the top, but then couldn't squeeze the seal in close enough at the bottom to get the other ring on.
At this point after trying for an hour to get the Trail Gear swivel ball seals and rock rings fitted I admitted defeat and ordered some more genuine bits from Toyota.
Ball swivel seals.
I borrowed this awesome kit from work, must get me one of these. Great for knocking bearing races, and oil seals in with.
New oil seal in.
Followed by the half shaft and CV.
New ball swivel seals went on next.
Fitted the new wheel bearings into the hub next.
Bearing race got tapped in first.
Followed by the bearing.
Followed by the oil seal.
Cleaned the disc both sides with thinners to remove any oil/grease and re-fitted the brake calliper.
Other side.
Filled the diff up with oil next.
Following on from this thread:
http://www.landcruiserclub.net/forums/showthread.php/49298-Air-filter
My new air filter arrived.
Old filter out.
There is no point having a snorkel if the holes in the bottom of the factory airbox arnt sealed up.
Sealed the holes with more blue RTV sealant.
The next day when the RTV sealant was dry I could fit the new air filter.
Michael was busy repairing all the door cards on his 80. The guy who fitted his sound system managed to damage all the door cards by pulling the clips out of the door cards. So Michael used some of my Tiger seal (Thanks Nelson
) to stick on some pieces of aluminum that hed drilled some new holes in, over the existing damaged holes.
Some of the guys from the 4wd club had called by to see how we were getting on with our trucks. Both Patrol drivers.
I needed to repair the broken rear body mounts and decided that it would be a bit easier if I removed the rear bumper.
It appears that the swing away wheel carrier pivot has bent.
Anyway.........................bumper off.
I needed to remove the body lift spacers that were now embedded in the body.
I was pleased to find that I could get to the body lift bolt access holes, without removing the drawer system.
The bolts were an absolute bitch to get out, the one took over an hour to get out.
The spacers were pretty chewed up.
The body was pretty chewed up.
Using the reciprocating saw I started to cut the sides of the jagged hole square.
It was pretty tight with not much room to work in.
The otherside was even trickier as the exhaust was in the way, so that needed removing.
Rick, the owner of one of the Patrol's gave me a hand using his Bosch, Fein style power tool.
The Patrol owners suggested I should do a rear guard (quarter panel) chop, which is a common mod on Patrol's.
The bottom of the rear quarters were looking pretty rough, with dents and cracked filler.
So a few beer later and it seemed like an OK idea.
Out with the 9" grinder.
I cut below where I wanted the panel to finish to allow me to bend the metal under and create a lip which I can then rivet/tek screw/weld to.
Cut and folded up.
Other side.
Weapons of choice.
Couldn't quite get all the way through even with the 9" grinder so had to finish it off with the recip saw.
Squaring up the jagged hole.
This Fein style tool was invaluable as I couldn't get anything else in the enclosed space.
LJ should be a tiny bit lighter now.
The cut out panels will need enclosing in on the bottoms.
So the next job was to make some cardboard templates.
I took the templates to work and cut some 2.5mm steel on the guillotine and bandsaw.
I also measured the internal dimensions of the section of body where I've cut out following the bodylift spacers smashing their way through the metal.
The plan is to completely fill that hollow section of body with metal, and then bolt through the new metal, back through the body lift spacer and chassis.
So I took the measurements to work and had a look in the scrap bin and worked out how best to construct the body inserts.
Quickly welded up and ready to now be inserted into the body and welded in place. Just need to mark and drill them first.
After work tonight I used Michaels pressure washer to wash all the sections I will be welding.
I also washed the bumper.
Before tucking LJ back into the garage.
Freezing cold and raining heavily tonight in Melbourne.
I'm taking LJ to work tomorrow and after work I will have 5 hours to get the welding done and rear bumper re-fitted. Also need to re-fit the last section of exhaust.
Then Friday afterwork were off to the High Country for another trip.
Apologies if you guys were expecting something more dramatic when I mentioned taking a 9" angle grinder to LJ.
