Thanks guys.
My suspension has needed replacing for a while, in fact I'm not sure its ever really been right. I guess Ironman suspension is cheap for a reason.
Michael mentioned that he had got a load of different 80 series springs in standard height, +2" and +4" that I could try on LJ.
My rear springs were particularly bad and were almost coil bound.
So Thursday after work (I can use the workshop for 5 hours after work every Thursday.
) We got LJ on the hoist.
And removed the rear springs.
The Old Man Emu +2" 80 series front springs looked perfect.
Springs fitted and with LJ back on the ground the height looked perfect.
And the springs had loads of space between the coils.
With the rear done we turned our attention to the front.
Michael removed the bottom shock nut so that when we lifted LJ up the axle would drop and we could pull the springs out.
After hunting round 2 factories we found some Old Man Emu springs that looked perfect. They are +2" springs off the front of my boss's 79 series cruiser.
One end of the springs fitted perfectly with the spring perch on both the axle and the chassis, but the other end of the new spring tapered in and became too narrow.
So we put my old springs back in for now.
I really wanted to use the 79 series springs as like the back they are virtually brand new in that they were fitted used for a few weeks and then they were changed for taller ones to give more lift.
Also 79 and 80 series springs will be easy to source pretty much any where in Australia, where as LJ70 ones wont.
Not a problem I had a cunning plan!
Cardboard, masking tape, scissors, pen, tape measure and a short time later we have a working prototype of a spring adaptor!
It follows the contour of the spring perfectly.
I drew around a suitably worn angle grinding disc and then cut it roughly to shape on the guillotine.
Marked, centre punched and drilled a hole in each.
Marked and cut 2 slightly smaller discs.
And again, marked, centre punched and drilled a hole in each.
Found and cut some suitable tube.
Found a hole saw the same size as the tube, and cut the centre out of each disc on the pillar drill.
I cut some 20mm x 3mm flat to length and tack welded, and bent it around the 2 larger discs.
Before fully welding it.
I then welded the tube through the middle.
On Monday I will finish them after work.
Once the new springs are fitted we will lift a wheel on LJ and when the spring(s) are fully compressed measure and work out what length shocks I need.
Buying all new shocks I'm tempted to get Old Man Emu so they match the coils.
I mentioned to my boss that all my bushes on my radius and trailing arms are stuffed and I asked what he thought of Super Pro.
He said there too hard really and that Old Man Emu would be a lot better as there much softer.
There also dirt cheap, like £20 to change every bush on the truck!
I guess there the sort of discounts you get with suppliers like ARB when your spending thousands with them every month.
Anyway......................
As I left work at 5pm on Friday I got a call from one of the guys from the 4wd club, asking if I wanted to do a night drive. My response........................... Shit yeah!!
So we met up at 8.30pm and drove some of the extreme tracks around Telangi until 3.30am
Was a great night and LJ performed faultlessly!
I made it up Rocky Track without the waffles this time, even though its a lot more washed out and the rocks and boulders are getting bigger.
The front locker made a huge difference but it was still a huge challenge.
Rick was ahead of me and when he got to the top and was watching me come up he said it looked mad as my headlights were bouncing all over the places backwards and forwards as I had to keep trying different lines, as I fought my way up and over some of the huge steps.
Doing it in the dark definitely made things more interesting.
The new rear springs have made such a difference!
Didn't get many pics as it was dark and raining. But I did get a couple when the track was blocked by a fallen tree. Melbourne has been having some terrible winter weather lately and lots of trees have come down.
Michael got his chainsaw and we soon had the track cleared.
Was a great night, but a branch jumped out in front of me and cracked my windscreen.
Oh well the risk I take doing what I do and I wouldn't have it any other way.
Were away for the next 2 weekends in a row on snow trips in the High Country.
I think this 4wd obsession has taken over my life!
I spend all week getting paid to work on and make things for 4wd's, then spend nearly all my spare time driving them or working on them.
Great fun!
Fellow club member Paul dropped in for a cuppa yesterday.
Great to finally meet you Paul.
Oh and I've remembered what wood the deck is made of, Merbau.
