Next update................
The rear axles got a second coat of paint.
And then my original factory locked LJ78 one, along with the arms got put on a trolley and wheeled out to the the 78.
Where I bolted the trailing arms loosely to the axle. (its important to do all the trailing arm/radius arm and panhard rod bolts only finger tight until the vehicle is back on the ground with the wheels on and is given a quick bounce up and down on the suspension, then everything can be torqued up.)
I could then push the whole thing under The 78 and bolt the arms to the chassis.
I then swapped the trolley for the trolley jack.
Then it was time to fit the springs.
After our first off road trip in QLD I realised I needed to change the rear springs for the stiffer +150kg ones I had, because the softer ones were bottoming out at times.
Stiffer on the left, old softer ones on the right.
And I also decided to change the rear shocks for the slightly longer OME ones that I had.
And the final part to change were the bottom spring rubbers as they were badly worn out and looked like the previous owner had butchered them.
That lot were all soon fitted.
The panhard rod needed fitting to the axle next.
Now for some reason Superior Engineering dont make (or at least didnt used to make) a panhard rod for the later rectangular headlight Bundera's/Prado's/LandCruiser II's.
The panhard rods are physically identical on the earlier and later suspension setups, the only difference is the bushes on the ends, or to be more specific the metal tube inserts in the bushes.
So in order to properly fit this earlier style panhard rod to my 78 I found a piece of solid rod at work the right diameter and bored a hole through the middle of it on the lathe, because the old tube insert was far too big for my bolt.
That was soon pushed through the bush using a clamp and the panhard rod was bolted loosely in position.
Next I picked up the freshly rebuilt locker!
Now this cost a fortune to have rebuilt, it really did.
But with it being such a rare diff and the fact no one does a ring and pinion that fits it, it needed a highly skilled specialist who was able to make spacers and do all sorts of machining on it. Your average diff/gearbox shop couldnt have done what this guy did.
He also fitted a solid pinion spacer (something that is essential on all Toyota diff rebuilds) and all new bearings.
This is who rebuilt the diff for me:
http://www.ttdrivelines.com.au/
I also got my E locker back from him, which will now be getting fitted in my front diff.
That got put on a trolley and slid under The 78.
Along with a tube of silastic.
The mating face on the axle casing got a good clean up followed by a good bead of sealant.
I then lifted the diff into position and then left it sat in place for 30 minutes, before doing all the bolts up. This is to let the sealant set a little bit as otherwise it tends to just all squeeze out when the bolts are done up.
Next the halfshafts and brakes went back on.
Followed by the wheels/tyres.
I then jacked the rear axle up so the wheels were just off the ground and started the engine and let the clutch out with it in 1st low.
This was because I wanted to see if any power was getting to the actuator plug and I know there is a speed sensor in the gearbox/transferbox that needs to tell the diff lock computer it can engage the locker or not.
But I couldnt get it to send any power to the actuator plug.
I did however find that when manually engaging the locker with a screwdriver through the hole where the actuator bolts on, that the light on the dash does stop flashing and goes to a solid red light when its engaged. So if I do end up converting it to a manual cable operated locker, at least the dash light will still function correctly.
So after testing the actuator some more and deeming it dead, I bolted it on anyway to seal the hole.
I picked up some oil.
And pumped it in.
One of the biggest reasons, from what I have read why the locker actuators fail is water getting into them!
Mine had a breather tube, but it only went as high as the chassis rail.
So my next job was to fit a new breather tube that will run into my diff breathers which run up to the top of my snorkel.
Actuator guard back on and that job was finished.
Next I got The 78 on the hoist at work to give it a thorough check over. I checked all the diff/gearbox/Tbox oils, all of which were fine and gave the prop shafts a squirt of grease.
All wheel bearings felt OK and everything looked and felt good.
My next job was to plumb in my 50 litre water tank behind my rear seats.
I found most of the parts at work.
I just had to buy the big fitting that screws into the base of the Boab tank.
All done and ready to screw on.
The end of the hose with the tap on will be stored here on top of the gas cylinder and the hose can be pulled out and used with the rear seat in the normal seating position, I will only have to fold the seat before a trip when I'm filling the tank up.
I briefly mentioned this pic in my last update.................
Well I thought I had come up with a brilliant idea!
The car wont fit under the second car port (where I really want to store the vehicle, behind a locked gate), with the roof rack on..................
So I pulled the winch rope out, threw it under the car and attached it to the rear recovery point and thought if I winch in it will compress the suspension a few inches and I will be able to drive the car though and then let the tension off the winch rope.
Well it didnt go at all well.
The winch rope snapped and the rope got badly jammed up on the drum.
So after using the foklift truck at work to pull the rope back off the drum, I put it in the Mrs washing machine while she was in bed one morning, then after watching a youtube video detailing how to do it, I made a new loop on the end for the hook to attach to.
As winch ropes need to be wound on under load I just wrapped it around the bullbar for now.
The top tether extension strap arrived.
And the baby capsule was soon strapped into position.
The new top anchor point and extension strap worked perfectly.
I started loading the car for the Easter trip.
I found that the double stretcher we sleep on, one of the chairs and the compressor fit nicely on the floor under the baby capsule.
But one chair will have to go in the back for now as on this trip I'm hoping the only thing on the roof will be the Oz Tent RV5.
The fold up table and cooking plate fit nicely on top of the drawers and felt very secure once strapped down to the new tie down rails.
So The 78 is now almost ready for next weekends 4 day High Country trip!
