Finally got around to draining both the GB and TB and putting in a 75/90W GL4 synthetic gear oil, the oil is designed for:
'manual gearboxes and transmissions and for use in mid severity conditions in light commercials and some cars, not for use in differentials using hypoid gears'.
First impressions...............not happy! Might be too early to tell at the moment but, I got the feeling that the gearbox internals were still spinning when trying to change 1 -2 and 2-3, something the synchromesh should have coped with...unless they (the synchromesh) do not work well with such a slippery oil that is also light enough allowing the internals to spin so freely when cold? To add credence to that 'feeling' is that from cold I had to select reverse and it 'crunched' as it went in, something it has never done before. Where I park in the underground garage I always have to reverse out of the parking space, so this is something I would have noticed before, I accept there may be no synchromesh on reverse but this is a new thing. I will leave it for a couple of weeks but the 80/90 dino oil was better......definitely. So depending on a few miles down the road I may go back to a typical 80/90 mineral GL4 which should be easy to obtain, I bet my gearbox insides are cleaner than yours!!
regards
Dave
regards
Dave
