Sam
Hi folks - I hope you and your loved ones are all doing as well as possible right now
I find myself heading into winter, in obviously difficult times, with a morning start issue. An LC morning start issue to be clear
Here's what I've got....
2003 LC4 with approx 128,000 reliable miles.
Full Toyota history up to around 100,000 then regular oil changes and tyre kicks etc by me from there.
Fuel filter has around 20k on it (last thing Toyota garage did).
Here's the story.....
With no noticable issue in the days previous, the ol' girl took a good 5-10 seconds to start early one morning. Never taken more than a turn before (other than when a battery died). It was cold but not below zero. I had a good healthy chugging like it was trying to go but no k'booms. Then on a second key turn and a few seconds of chug I got life.... and a yellow warning light.
Engine was running well and had a good idle. I let the engine warm up a little then turned it off and back on again. Light went away and it started on the first key turn without hesitation. Later that day (a good 10 hours later so cold again) and it started instantly on the key turn. No warning lights and all good.
Next morning same issue. Prolonged chugging and no k'boom. Eventually a k'boom and a warning light followed by instant starting and no light later in the day. Rinse and repeat for about 2 weeks. Only seems to be an issue on the first start and only first thing in the morning. Both in single and double temperature digits (deg Cs). Warning light mostly (but not always present) immediately after starting - but always clears on a restart.
And that's about where I'm at. There was a little bit of relunctance when trying to accelerate a short while after starting yesterday - felt like a fueling issue - but that cleared up after a quick restart and all was well for the rest of the day.
I'm reluctant to risk being told I need a new fuel pump and injectors for the bargain price of an arm and 3 legs - at least not without checking in with you lot here first.
First time in 120,000 miles I've had real reason to doubt the LC. Don't like it. Feels like the universe is out of balance....
So, over to you lot. I humbly await any scrap of ideas you might have to offer.
Thank you - I appreciate your time.
- Voltmeter on the batteries (seperately and together) suggests they are fine.
- Doesn't seem to help if I sit and listen to the fuel pump buzzing away for a while before trying for k'booms.
- Buddy at a local garage plugged in a box of pixies which read a code 23 off the ECU ... which I "think" is fuelling related (?)
- Curly glow plug light goes off almost straight away as normal.
