Paul
Straight through, no issues or advisories
Heard some news though.............
The tester is also a VOSA officer and informs me that ALL vehicles will have to have a current MOT soon and it will be an offence to not have it tested even if sorn, you should be advised of this on your next test. It was actually tried some time ago which is why the sticker appeared on your certificate, due to data protection issues it could not be enforced as Siemens (who will be checking) could not access the data but this will change over the next year.
What is also coming in is new rules on trailers. Not going into all the Tacho laws, but if you use your cruiser for work and it has a tow bar (which is an intent to use) you will have to have a tacho as you have the ability to be over the 3.5 ton train weight (7.5 for private as before) where one is required for professional use over 30 miles from your place of business, of course you only have to take the ball off and you are ok. Receiver hitches will also allow you to escape the regs.
This is only checkable by a VOSA inspection.
