ok but will need thicker washers to compensate for the bigger holes in the plates really.How were the plates and U bolts?
Thanks. The legs are 77x38x5mm wall C channel, the inner rail 50x50x5mm wall box, the outer rail 50x50x3mm wall box and the outriggers are cut from 75x50x3mm wall box. The outriggers were capped where they'd been cut and shaped, to regain strength. They are not a lightweight design, it's not a lightweight truck Sandwich plates are fine, I used that method on other slider builds and would again. The U bolts are not a standard size they are custom made for the job.Looking great Jon.
I have a couple of questions. I made a set a few years ago and used 25x50 2.5mm rectangular box for the legs and found that they weren't stiff enough for jacking. What did you use? In fact would be interested in the spec of all the steel used as I might get round to having another go later in the year.
When it came to mounting I used plates to sandwich the chassis legs but think that U-bolts would be a neater installation. Are they standard U-bolts or did you have them made?
Thanks. I did put ali plate across the outriggers to make a deeper step, as in this picture below In this form they are what I was aiming for. Without the ali plate was just a test fit to check clearances.Great work as usual Jon, the sliders look really neat. The box section works, possibly better then the tube, and should make jacking easier. It should be easy to fit an ali plate to make a step. The connectors between the inner and outer bar look a bit fiddly to make. What is it about them that is not what you had in mind?
Not yet afaik.Available in 35's Jon?
That's just my first guess at a pressure to start with Steve, to put my comments about them in context.good tip about pressures Jon, cheers - was wondering what to pump them upto
Looking fwd to the new beasty
It has a bit of lift from running uprated springs but not much I don't think, 20mm or so maybe.Hey Jon your 80 is looking very smart.
Have you given it a lift or are you running stock height. I know at stock the 80 can quite easily handle 33" tyres but just wanted to ask.
