Chris Green90
Crawled under the car this morning to replace the Diff Lock Actuator and found this.
I guess this solves the problem of why I have been hitting the rear bump stop alot. It must have been through an MOT like this...That cant be right can it.
So the question is what is to be done...Does it mean a new axle, can I buy the mount and get it welded back on...could I just weld some plate down both sides to sure it up???
Its the part circled in gray if that helps at all
Any help or advice is very much appriciated, Need this sorting before Tidworth.
