larryseaman
- Nov 4, 2021
Hi all, in the last few days I've started to get some low level groaning/ whining nose when turning the wheel and it seems to be getting slowly worse each day. I've checked the power steering reservoir and it's not losing fluid (or much at all as I only top it up a few fluids oz. every 3-6 months) and the fluid isn't airated when I turn the steering when it's jacked up.
I've checked the high and low pressure lines and there doesn't seem to be any leaks or cracks in the pipes.
I've also checked to steering rack which is only a few years old and there isn't any leaking coming from that, having removed both rubber boots too. The vehicle is 23 years old and it has the original power steering pump so I'm wondering if it's time to replace the whole pump or just check the seals?
I've also noticed that the steering rod which comes from the steering rack up the the steering wheel (sorry I don't know it's proper name) has had its rubber seal completely worn off at the top; please see the photo attached. I'm wondering if this has anything to do with the noise I'm hearing or does the seal serve no important purpose other than for dust/ water protection?
Final question!.... I'll need my vehicle for an airport run in a week's time but might not get chance to repair the Cruiser before that; is it safe to drive/ keep driving in this state or could I get seriously stranded with a break down?
Thanks so much in advance for any support!
