Uh oh...Brett said:Gav Peter said:Willdo my best buddyPaul said:Can you take some pics of the actuator replace
Where are they then
Yeah, cheers lah. Well chuffed. Looking forwards to trying it out next weekendChris said:Awesome! No stopping you now Matey!
Gav Peter said:You can get to the locking pin with the actuator in place. If you look on the second pic, you can see (well, almost...) the plate with the switch in, just by the two studs... If you remove the switch & then take off the 3 bolts holding the plate on, you can get access to the actuator pin. You could probably leave the switch in if required...
You could try spraying WD40 down the breather pipe, this usually gets sticky actuators going again.Brett said:Ok, I'm with you now
So, if I remove that cover plate I should be able to hopefully spray some lube in there & hopefully manipulate the pin into moving again.?
Thanks for the photos & the redline markup Gav.
Rob said:You could try spraying WD40 down the breather pipe, this usually gets sticky actuators going again.
