A battery will never draw more than 25A or so. Even totally flat that's the max it will deliver. Given there is a winch when the winch is operating the alternator will hit maximum output so the wiring between the alternator and the battery (or winch feed) will need upgrading to cope with the maximum output of the alternator. There is no need to upgrade any other wiring.
Hi OG,
Sorry but you are quite wrong with your explanation that your battery will never draw more than 25 amps or so.
Who told you that, or how did you come to that conclusion?
If your battery was flat, like just 10 volts at open circuit terminal voltage, then the internal resistance with a pb battery will be very low.
I can work it out, but bore you to death
The lower the internal resistance of the battery, then allows the alternator voltage to rise, past it's general charge voltage of 14,7.
When the alternator feeds into a pb battery with low internal resistance, the battery will try to pull the alternator volts down, as it pulls the alternator voltage down, the amps rise proportionately until stability is met.
You could quite easily have 60 amps or more feeding into a flat battery, because I = V over R
Having a larger alternator gives you the ability to refill the discharging battery (via winching) however, as the amps are being used up out of the battery, the alternator is replenishing them also.
So a larger capacity alternator will replenish the used "winching amps" and at a point, when the amps are flowing out of the battery faster than the alternator can resupply them, then the alternator becomes the winches primary power supply.
Gra.
