I'm the wrong person to explain these things, but a 100 amp alternator doesn't just produce 100 amps. it is CAPABLE of producing 100 amps. Until then it like driving a Fiesta against a Pagani Zonda. At 70 mph they are both doing 70 mph. No difference. But the Zonda is capable of more. But only if you require it to. If you have a 10, 000 amp alternator but only ever ask 60 amps of it - that's all it will do. It's an 'on demand' device. There is little that is driven directly from the alternator. Most power comes from the battery and the alternator puts the power back into the battery as it's used. Having a bigger alternator means it can do that faster. I appreciate your windows might be much faster, but that may and I stress MAY (cos I isn't a scientist, is it) be more indicative of your battery.
Delighted to be corrected, but you could fit a monster alternator and it never get anywhere near what it can do because you cannot create the demand. A standard 80 amp unit should be capable of replenishing the battery with you lights, heater, demister, CD on etc. That may well entail full load. I have a bigger unit because of the rear battery and my tendency to use the rear winch a lot. I need that capacity replacing fast. But there's no alternator that can supply a winch at full pull. ie if you removed the battery, would the alternator run the winch load? Nah. It needs the battery as a buffer. So, again as an amateur, I think it's unlikely on a standard motor, or at least in standard driving, that your alternator produces anything more than the old one did when it was working properly. Raising the revs doesn't necessarily raise the output. More volts yes between 12 to 14.4 but not necessarily more amps. Producing 110 on tick over I presume is with some sort of load. If there isn't any, it doesn't produce any current?
Someone with a science brain please confirm or debunk the theory here. Anyhoo, glad it's working for yah, buddy.
