That was pretty much my understanding Dr Gra. And at the point where the battery and alternator sort of level out, your winch won't be running anymore (under load) because the flattened battery and running alternator simply cannot power it. So wait a few mins and go again. Of course with a standard battery, deep discharging isn't recommended. So best to not get to the point where the winch IS stalling. I do like Rob and OGs points about upgrading the cable between the alternator output terminal and the battery. But not sure it's necessary. Maybe you can do the math. If a flattened battery pulls 60s amp, then it could do that from an 80 amp alternator now, so the cable should be ready for that, yes? I am not sure under what conditions my alternator would be supplying its max of 120 amp really. But I have three batteries and I do on occasions run the front and rear together.
I bought the higher capacity unit because I needed a new alternator and it was the same money. The bearings had gone in the recon unit I had on there. I didn't specificaly set out to upgrade.
