Rusty Rear cross member
Graham
I was under my daughters 2001, 100 series earlier today, and there is quite a bit of corrosion on the rear cross member, and about the last 15 inches of the side chassis rails.
As she plans on towing a double horse box, I feel this cross member needs replacing, or strengthening.
How to go about it ?
Replace, or bolster it up ?
Graham
Shayne
No point in welding to rust so cut that away and see what your left with .
Graham
Thanks Shayne,
Can rear cross members still be had ?
Or all second hand now ?
How about the last 15 inches or so of the side chassis's ?
Cut from a donor ?
Shayne
Try your luck at a breakers i suppose cut and shut would be a lot easier than faffing about fabricating bumper hangers or whatever , then brace it and you end up with stronger than new .
Super Moderator
europe
Is it really that bad Gra?
Geoff 28
First things first Graham, get the rear bumper and spare wheel out of the way so you can have a proper look!
Once you’ve got over the sorry state of the rear bumper support you’ll have a far better idea of how bad the corrosion is.
Shayne has suggested sourcing from a breaker but unless you can find a late one you could well find a donor is just a bad!
If the cross member does warrant replacement you may find OE is still available but I would imagine a fabricated replacement will be cheaper. There’s plenty of meat in the chassis rails so if they’re only suffering from surface corrosion they should stand cleaning up prior to any welding.
Super Moderator
europe
Subject to precise conf of course, Toyo says this......
Graham
Hi Chris.
Want to take a peek?
Your not too far away.
I could drive it over.
Graham
Tha
Thanks Geoff
Super Moderator
europe
Always good to see you. Happy to have a look, a chip and a bash.
