Started brewing at 7am
Weighed out my grains, 4.5kg of place malt, a handful please of choc malt and crystal malt
heated up around 12-14l water to 80degC in a boiler
poured the water into my "mash tun" - a cool box with tap fitted and a loop of copper pipe with slots cut on underside, to act as a strainer
when water is 72 DegC in mash tun I stir in the grain and make sure temperature is 65 +\- 2 DegC
put the lid on an leave to mash for 90 mins
adter about an hour I put 15litre of water on to heat up to 90-100deg
when mash finished, I run some wort off from tap into a jug and pour back in to mash tun, this is to clear he run off wort to reduce fines, the grain bed acts as a filter to the fines.
then I put boiler on top shelf, mash tun in middle and another boiler on floor
you want 80degc water to come from boiler and I have. A spinning t piece in mash tun that sprinklers he water onto grain and rinses the grains as I run off the wort to 2nd boiler. This is called sparging
next step is to bring the wort upto the boil, and chuck the main hops - about 75grams
and boil for 90mins, adding about 15grams of "aroma" hops for the last 15mins, and some stuff to clear the beer and my copper coiling coil.
i then connect cooling coil to a tap and run cold water through to cool water to under 25deg and then run wort off into fermenting bucket and add water to make it 25litre, add yeast and leave for a week to make the ale
