Beau
- Jan 28, 2011
What did you remove just the pipe from exhaust manifold to the egr valve ?
As we talked about earlier in this thread turning up the fuel is something of a mystery still , i can get the same results from half turn as i get from 3 full turns on the screw and as you said some get no joy at all . I would use smoke as your indicator , turn it up see if it cures your starting problem and if it does you can work at finding the lowest fuel setting without the worry .
Yep, the pipe that runs along the back of the engine.
And I'm a bit scared of turning it up too much as I would rather avoid a runaway engine situation again
