I have started to try to diagnose a stuck and leaking sun roof.
The roof appears stuck in the closed position.
I can hear the motor try to move but the roof does not budge.
The handbook describes the emergency procedure to close the sunroof.
The description leads me to think that I am missing the spacer and washer that go on the screw/bolt that one must remove before manually cranking the sun roof closed.
The instructions explicitly say not to lose the screw, spacer or washer otherwise the roof won't work!
My question is - can somebody please give me the spacer size so that I can make one?
Maybe then my roof will open?
I attach pictures of the instructions and my motor.
Is the spacer normally visible with the headlining removed?
