I have to say that I'm loving my new KYB 80 series front springs on the rear of mine and could not be happier
http://www.landcruiserclub.net/foru...eries-front-springs-fitted-to-Fierys-rear-end
They were only £65 for the pair and if combined with a pair of 80 series rear shocks (prices vary but about £100 the pair for Monroes) that would be the back end done
Then up front if your still running standard suspension in particular standard struts/shocks then a pair of 25mm Top Strut spacers would be cool. Shayne just got 55mm lift fitting a pair of 25mm Top Strut spacers to the front of his. All of this would be about £100 from off of the bay with a pair of diff drop spacers, but I know someone on here that has a pair of front Top Strut spacers kicking around his garage that would be slightly cheaper I'm sure and I've a set of six Hi-Tensile bolts with the heads machined down to 4mm thick that would go well with them. They wouldn't be massively pricey I'm sure
You could be all done for around £265 including dropping the front diff
I do need to update my 80 series spring lift thread as I've made some significant findings with regards to Top Strut spacers and extended travel struts/shocks!!! The up shot is that the thickest Top Strut spacer you can reasonably fit with struts/shocks with extended travel is 6mm, but I'm sure with standard length struts/shocks a 25mm Top Strut spacer would be fine. With extended struts/shocks and a Top Strut spacer any thicker than 6mm you get massive top ball joint bind!! In particular on the O/S with an aftermarket lift kit IM, OME etc due to the slightly longer spring that they all seem to supply?! You could possibly get away with a 10mm Top Strut spacer on an already lifted truck if it wasn't for the slightly longer O/S spring!
If you did decide to keep the front end standard and use Top Strut spacers to gain the lift you could still fit a pair of new KYB standard springs (around £60 the pair) or maybe even a pair of up-rated Milner ones. It's the length of the struts/shocks that need to remain standard if using thicker Top Strut spacers.
Re-cap
Rear suspension
New 80 series KYB front springs £65.00 the pair.
New 80 series Monroe rear shocks £100.00 the pair.
Front suspension
25mm Top Strut spacer and Diff drop spacers £100.00 for both sides.
Leaving the rest as is.
Total £265.00
New 90 series KYB front springs £60 the pair.
New 90 series standard length Monroe front shocks £75.00 the pair.
Total for all new suspension plus lift £400.00
It's just an alternative idea for lifting a Colorado that I've been kicking around for three or four weeks now
