- Mar 1, 2010
Hi
I have 1996 24valve 80 with all original electrics including alarm. I noticed today that my alarm would not set and peering in to the car noticed that the heated rear screen switch light was on, together with 2 lights on the climate control panel. On opening the door and pressing the switch nothing happened but on turning the ignition on every thing works OK. So to recap if I forget to turn off the rear screen heater upon leaving the car, it will not turn off automatically as it should and the alarm will not set; also 2 lights on the climate control panel lit up.
I shall be most grateful for an answer.
Frank
Frank
