I can't remember as I have a set but just in case you don't know the old tip (I'm sure you do) make sure you can get the fill plug out first, before you undo the drain plug.
They can be little tinkers to get out sometimes. Dead easy to fill with a garden sprayer with the spray head taken off. Just fill it till it comes out of the filler hole.
Your right with 10 & 12 I did mine thursday. 24mm socket for rear
Probably not the place but I was sorry to hear of your disaster chris , up and onward though hey
BTW i knew the filler size because thats the one i tackled first
Magnetic drain plug had a film of metallic paste on it maybe 2mm thick. Guessing thats normal on a vehicle this age / doubt oil has ever been changed. No large metal pieces though
The metal paste is normal especially if the oil has not been done before. If you have metal filings then there may be trouble ahead as these have to of come from somewhere.
Clean the mag plug re-fit and if you have any concerns then repeat the oil change and see what you have after a few miles.
