Whats this fuse box for and why does it look like this?
Mijkol Jones
australia
Can anyone adivice what htis fuse box runs as a few things have stopped working? see pictures It's located under the drivers side. (landcruiser V200 2014
Cheers Mijkol
I'm not familiar with the 200 series, but it's been getting wet hence all the frosting of corrosion all over it.
I'd start by taking the fuses out, and cleaning the contacts as best you can and replacing the fuses like for like and I imagine many of the things that have stopped working hopefully should come back to life.
As to where the water is coming from will need some more investigation
  • Like
Reactions: MGC
Thanks, it has been cleaned out and fuses replaced but things still not working and some others have gone out :(
When you say some have gone out do you mean the fuses have blown?
The only way i can imagine getting that clean enough to work correctly again is to remove it and soak it in limescale remover (toilet cleaner)
and even then the corrosion will return quickly though dialectic grease might keep it working .
Get to a scrapyard and look for another would be your best bet because either way your going to have to remove it .
Prob find all the wires going to/from it have corroded away. Give ’em a tug.
No not the fuses - it has been cleaned out and new fuses put in but I have noticed the atuo wipers not working anymore or headlight cleaners - think it may need an auto electrician ?
