That's the conclusion I came toRob said:Had far too much bling before...
I did an ATF flush on our Geartronic T5 V70 when we first bought it. From memory the system holds about 9ltrs but only 4/5 come out when you remove the drain plug after doing this pop the drain plug back in, then top back up with same amount of new ATF as you have But then remove the return pipe to the gearbox oil inter-cooler & fit a suitably sized bit of tube over it. start engine with other end of tube in a jug until about 2ltrs of ATF is pumped out Turn off engine, replace with same amount of new ATF and then continue until all is clear This took me 12ltrs of ATF till I was happy, others report 18ltrs Either way it cost me around £100 in oil and kit and took a couple of hours, better than the £300+++ that Volvo wanted to do the same jobAndrew Prince said:Flushed the ATF - got 6l out as usual... Old ATF didn't look great, even though it's been 1000-1500 miles since the last 6l flush.... Going to do the next flush soon(er) - I'll give it 50 miles or so to mix up with the old brown stuff and then put in some fresh red. I was hoping that the ATF would look better than it did. Not that dark but quite murky I think I'm going to buy a cheap 20l drum of Castrol and flush quite regularly until the ATF all looks nice. And then put in the synthetic stuff
Jon Wildsmith said:also painted the chrome surround on the grill black and the toyota emblem which I did gun metal grey, while I had the grill off anyway to change the winch solenoid:
hope that's ok with you Gav
Yup, all fine so far Jon - carry onJon Wildsmith said:cut the 1.25" outer tubes off my sliders this evening and replaced with some 2" tube that looks a bit less anemic
