Gary Stockton said:
Sounds like something I'd do ...
did you follow the handbrake bible - was it all applicable??
Jon Wildsmith said:replaced my broken drivers side CV joint, re-booted lower ball joint (while doing CV), inspected, greased and refitted front prop shaft, reset drivers side wheel bearing preload.
Just the ball cage in the CV. I'll talk about it in the Lincomb thread when it comes upAndrew Prince said:Was the damage limited to the CV then, Jon? Front diff all ok?
There was a fair amount of damage sustained today - conditions were even greasier than yesterday.
Yes, genuine care of uncle Rubie. I'm not sure wether to think something stronger is needed or if that one was fault, the original ones have survived much worse.Julian said:Was it the Toyo one you got, 10k is very short like for an oem one!
Shame those American after market ones haven't turned up yet. (RCV I think)
You should be inside the aircraft and hear them, I sat in a Shackleton (descendant of the Lanc) while they ran up the four Merlins, to use a much overused word, it was truly awesome!Birder said:Was out doing a few bit on my 75 and taking pictures of adding bits for my build log and the Lancaster came over my house very low. I see it quite a lot as I live 5 miles from where its based but normally by the time i get my camera its gone.
The noise of 4 Merlins is just amazing.
Birder said:The noise of 4 Merlins is just amazing.
