tomrichardson
- Apr 3, 2010
i wonder if someone with better wiring skills than me may be able to help.
i'm trying to get to the bottom of the fact that none of my interior lights work, or have done so for the past 4 yrs of ownership.
i have a copy of the fsm, with wiring diagram of the interior light circuits, and also pictures of the connector blocks throughout the truck.
i am gettin power from the dome fuse, through to connector EA1 which is located under the washer bottle.
this is about as far as it goes!!
i have located IE1 and BL1, both under the passenger kick panel. there is no 12v feed at these points.
also, i cannot get continuity between these two plugs, although the diagram says i should be able to.
looking at the wiring diagram there is a point at which 5 wires are joined. where is this joint and is it likely to be a connector of some sort or will the wires be soldered together in the loom??
if i apply power directly to IE1 pin 1 i can get all 3 lights to illuminate in the "on" position, but nothing in the "door" position.
i feel like i'm going round and round in circles and its starting to do my head in. i'm tempted to run a permanent feed to the lights so i can switch them on myself when i open the door!!
any help and ideas greatly appreciated. thanks, Tom.
