100 Series Bull Bar Options ?
Churchy91
australia
Hi,
I am currently searching for a s/h winch compatible bull bar to fit to my "01 solid front axle 100 series. I am just wondering whether something off an 80 or 105 series will fit without modification. or if I need to source something specifically built for the 100 solid axle.
What Jon said, unless yours is a custom build, then it IS a 105… be aware pre and post 02 have the bar sitting at different heights. A 100 (IFS) can be modified to suit. Depending on brand, the bar itself is sometimes the same and only the mounts vary. There are about 500 different ARB bars for 100 and 105s, some vary only the mounts, most vary both.
An 80 bar will bolt up (same chassis more or less) but is too narrow and will require a huge amount of work to make for. What country are you in?
