Michael Knight
- Feb 20, 2011
Good day all ! I'm new on the forum and I own a 1999 J90 model Prado equipped with the 3400cc V6 four cam engine, automatic transmission.
It's due for a 120,000 km service and I'd like to know what needs to be done. Our Prado is a JDM spec used vehicle imported from Japan so it didn't come with an owners manual.
So far I know the following :
1) Transmission fluid needs to be changed. Whats the dry sump capacity as I will be using the machine to change it. How many quarts will I need?
2) What grade of oil is needed for the rear differential and Transfer case?
3) Where on the steering rack do I drain out all the power steering fluid from ?
4) How to reset the dashboard compass ?
5) What grade of Dexron should I use for the power steering ? Should I use Dexron ?
Any advise on the above and anything else that has to be done will be greatly appreciated.
Cheers !
Cheers !
