My Hilux Build
AndyCook
scotland
Hope I am allowed to document build of my Hilux on here :eusa-whistle: after all its a Toyota :icon-cool:
Starting with some accessories for the rear tub, a removable storage system.
First I purchased and fitted a Bedrug to protect the load area, this is waterproof and can be jet sprayed and carry logs/junk etc when my storage system is removed.
I have ordered a custom made N&J aluminum overland canopy to be fitted at some-point in next few months, once it has been fabricated.
In meantime I have started on drawer build. I am using the method Sam used after discussions with Chris.
The main frame being 30cm cable tray, and I am building a system very similar to the African Outback drawers.
Sealed cartridge bearings used for the runners.
The drawers will be around 30cm in depth, 50cm wide and 120cm long. there will still be 25cm space at the front of the tub for water-tank etc. and 20cm wide spaces at each side, for leisure battery and other stuff.
so I made on-side from the cable tray after cutting and folding it.
I will be bolting profiled "cargo track" to the floor of the tub, then the removable drawer frame will bolt to these. when the drawers are removed, other tie-down loop accessories etc can be fitted to the cargo track, or a rubber strip I bought can be inserted along it to fill in the channel holes etc.
Then the otherside
bolted some bearings in place
The fitted back in tub, after adding some extra bracing
plenty of room for leisure battery in the side wings
And useful space at front of tub for water tank and other kit
Fitted more bearings and test fitted the aluminum channel runners for main drawers.
The unit top and drawers will be made from 12mm hexagrip
My plan is to make the drivers side top of unit a sliding panel, above the drawer, as a fridge slide - like the AO system
so both can be opened/closed independently
thats all for now :)
Brilliant idea on the drawers. They are coming along very nicely.
well done good idea with the electric channel. what you going to make the drawers from sorry cant wait.
stu
brillent idea. well done all that came up with it.stu
Great start Andy. Looking forward to seeing how it turns out :-)
Sent from my GT-I9100 using Tapatalk
Thanks for the credit there Andy. It was my idea but I never made any. Quite a bit of work but a MASSIVE saving. Ben went down that route too with his drawers. It's all that the African Outback ones are made from really. Once again it's the thinking that you pay for not the material. I might make a small set of vertical stacking ones for the back or to go where one of the rear seats fits. 3 or 4 drawers maybe. We'll see.
Nice work buddy. Tidy as ever.
Very nice and a great idea. Nice motor too.
Flipping fantastic, im watching with much interest and will follow suit.
Andy
do you have a supplier for handle / catches please. love the idea and getting the bits together now. I think i am going to do different size drawers.
stu
Andy
stu
No - just been looking on ebay and searching on here for them actually
i have flight case handles aready from my old drawer system
but looking for a different latch mechanism, preferably a sprung slam latch
i looked at a supplier i used to use for catches and they dont do them. there is another company i know off but cant remeber there name.
stu
I am between jobs at the moment, so cracking on with my storage drawer build
Fitted cargo track, and protective rubber strip prior to filling the tub with elm logs i was shifting from chopping area to my log store
Fitted my drawer frame onto the cargo track bolts
Cargo track - T-bolts
strong shelf brackets used to make "wings" on sides of drawers for storage cubbyholes
the side wing area
cutting the Buffalo board sheet
Drawer tops made from buffalo board
one of side wings
Securing the top of drawers to the frame with rivnut inserts
space inbetween for fridge slide
fitted in vehicle
flush hex bolts secure board to frame via rivnuts
Those are a thing to behold :clap: Love 'em :icon-biggrin: We need more dimensions and part number though, else how are we supposed to make our own :icon-rolleyes: Perhaps some links to suppliers :icon-smile:
