2LTE engine loads of blowby and blue smoke.
australia
have an lj71 with the 2lte engine. blows heaps of smoke on idle and when accelerating from idle especially. loads of blowby coming from oil cap. have a theory that the blowby is pushing oil past the stem valve seals and up the hose into the turbo crossover pipe (intake) and then burning. has anyone else had a problem with this?
Not had that on my 70 series, but when was the last time it was serviced, all filters, oil etc ?
Could be simple or much more involved, hang on for some better input.
Will, something else I thought of, egr and throttle body choked up with sticky, black, oily gunk.
And on a lesser scale, inlet manifold.
When I had these off my 78 for unrelated work, they were in a right mess, which needed carefully scraping out and using a brush and loads of paraffin in a makeshift parts washer, needed plentiful supply of rags too !
