Beau
- Jan 28, 2011
Tons of 4runner 3rd gens here in the states running on 35's which use same suspension as our 90's. Normally requires cutting the inside sill, at LEAST a 2 inch lift. Some do a body lift too. And you'd want a 1 inch diff drop unless you're gonna be binding your CV's at full droop. Diff drop kits sold here in the states, but it's really just a spacer on two of the Diff bolts, and longer bolts. You can make your own easily. You'll also need to add some spacers on the underside guard to get it to fit back properly.
It also helps to increase your caster and push the wheels further forward as normally it's the rear sill that's the touching point. I'm on 33's at the moment and think I can run 34's for sure without touching with my lift. I've got 2.5" up front and running the 80 series springs on the rear too.
https://www.toyota-4runner.org/3rd-gen-t4rs/108367-official-3rd-gen-4runners-35s-pic-thread.html
