active suspension
hi just found out about landcruiser info
can anyone help problems with AHC & TEMS on a 1998 HDJ 100 (active) i want
to convert to non active (feed up with problems & there does not seem to be
a long term fix)
thanks sam
The next generation of Hotmail is here! http://www.newhotmail.co.uk
Hi Sam,
What sort of problems are you having with the AHC? I've been doing a lot of
research on it so might have some answers.
Failing that you should be able to rip it out and replace with a 3rd party
fixed suspension arrangement.
What sort of thngs do you use the 100 for - do you want to go for a suspension
lift as well for offroading?
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Hello the Sam yes we are know all the real 4x4 guys in France the TEMS
do not work if you do real 4x4 passages. It get confused and put into
limp mode with all soft suspensions. So you are 400km deep in nord
buttcheekstan and your suspensions she is going on freeway in Germany.
.. bad situations!
So many forwarde think Toyota shops offre to cut the electronique
systeme all and put regular spings and shock instead. Not to expsnsive
too.
Do you not have this in hotmail.co.uk yet? May be you find some
adverts in some UK 4x4 magasines? I can give you French fixer shops
but that not help you much in UK, non?
The most bad situaions is the lastest hdj100 that ALL come with active
crapo from factory no alternative is there!
2007/8/15, Sam Smart <[Email address removed]>:
i have just removed the active suspension from my 1998 100 series to fit a
lift kit.
before i put the active bits on ebay i wonder if anyone out there is
interested in it
if so please email me [Email address removed]
Get Pimped! FREE emoticon packs from Windows Live -
http://www.pimpmylive.co.uk
lift kit.
interested in it
dont know if i am doing this wright to be posted on the daily email list but
hear goes
Sam
Hi Sam,
Don't worry, you are doing fine.
How did you get on taking it off - any major problems.
If you don't have any luck on ebay, keep hold of the bits because I am sure
that someone will be after some spares in the future.
07971 540 362
Hi Sam,
07971 540 362
