Chaps. Having some starting issues. I know that off roading the 80 usually leads to either the starter filling with crud or the alternator. Now before all the suggestions come in let's start from the basis that I am not a total donkey.
Yes there is fuel in it. No the fuel filter isn't blocked, not it hasn't been filled with petrol etc etc.
Here's what I can tell you. When you turn the key normally it starts on a touch. Recently had a couple of episodes where it didn't catch first time, but another go and it went. Then at Lincomb this weekend I didn't think it was going to start at all. it sounds just like flat batteries. Whuur whuuuuur whuuuuuuuuuuur then Whiiiir, brooom broom. The batteries are 2 years old. Topped up, reading well on hydrometer, standing charge good, fine with headlights on. Connections clean and bright. Starter came off tonight and the solenoid was hideous inside. Again. Like something from the sea bed. All clean and back together. Really thought this would sort it. But no, Whuuuur. It's firing up and running lovely - despite driving home from Lincomb with a blocked rad. Some of those hills got it pretty toasty.
Alternator newish and 120 amp kicking out top voltage. It sounds like there is massive load on the starter like it's trying to start a jumbo jet in gear. Could it be the gears inside the unit either needing a lube or a clean? Anyone had this before? It's pretty new itself since the last one caught fire. Doesn't sound likeit's kicking out properly either when it starts. I can't remember if the start pinion has a free wheel. Obviously when the start is flung out, it needs to lock in the starter ring. But IIRC you CAN spin the pinion backward like a bike wheel. Now on the bench tonight I couldn't turn the pinion at all.
To reiterate, this is nothing at all to do with fuel. It's not spinning over and not firing, it's struggling to turn over. Can't see it being the change over switch either. But not sure how to test that theory.
Anything I might have missed?
