Anyone else have a grey wire as one of the 7 going to tow socket ?
Shayne
I've blown 4 tail light fuses trying to work it out . Old socket still looks brand new on the outside but inside was so bad not a single wire was still attached .
Only thing I know for sure is the standard socket wiring shown with all 7 pin does not work .
Are you 100% sure its a grey wire and not a faded white which would be ground?
Heavier than the rest white I'm assuming is the ground .
Actually having removed the jack housing to see if the grey followed on from a different colour just before it went dark I find the heavy white was likely earthed via a large ring held by housing bolts .
Heavy white ground wire wasn't connected me thinks , I removed the jack housing bracket over christmas to knock out a dent and fit new tail lights so i guess it fell off when i undone the bolts and i never noticed to put it back on .
Also worked out there has to be a jumper wire between my grey and black left and right tail lights connections in the socket .
So in case it helps anyone else -
marked on the vapormatic (farm shop universal standard)
1 yellow = left indicator
2 Blue = Fog
3 White = Ground
4 Green = right indicator
5 Black = right tail light
6 Red = brake lights
7 Grey = left tail light (centre)
As stated add a wire connecting 5 and 7 and Bob's your Auntie Mavis .
Is this a satandard 7 pin plug? If so:
5 Brown =Right Side light
7 Black = Left side light
There's no Grey is a standard 7 N plug
I know thats why it confused me , ain't no 30 year old virgins , I removed maybe 30ft of wire relating to gadgets fitted retained/removed by previous owners while I was at it .
No brown wire going to socket in my 80 .
