You trust the guy your paying to replace them but you don't trust his advice that the old ones are good enough to go back in
I used to always re use the bolts Clive untill I came across an engine that had had the new acls and old bolts reused. One bolt failed and a con rod went through the engine. I don't risk it anymore for the sake of £70 from the dealers.
Always your own choice and as said I used to always re use the old bolts.
Changing your bearings isn't a scare factor. It's piece of mind. I had an engine on a personal truck let go on me with low miles on it. Cost me a lot of money to put right. Far more than a £200 job to change the bearings.
I agree its very very low that one will let go mate. I'm not saying you will be ok though.
I've done it many times as others have but some people do end up the unlucky ones. I've seen far too many of these engines be turned into scrap due to bearings.
I think they say the stretch bolts can be used 3 times or mesured to see if there in tolerance.
