Well never a dull day, someone at another dealer is in for a telling off and the dealer a bill from us.
Intermittent running fault/minor misfire with no faults stored and job sent my way rather then sending it out.
Well after various tests all coming back fine I got my thinking cap on which ended up with the intake manifold removed, found this quite badly coked up so needed sorting. Also decoke of the cylinder head, we have a tool to do this without removing the head, blasting tool that uses very fine walnut shell blast media, blasts it in and hoovers it all out (just make sure valves are closed!)
Also found the cause of it all, cylinder 5 glow plug which looked new wasn't actually fitted all the way in as it'd been crossed in and barely half way in!
Straight edge is sat on top of some of the other glow plugs!
It snapped trying to remove so had to be drilled out and the threads re cut.
Same car had the rear brake pads fitted incorrectly, they have an inner and outer pad, inner pad is very difficult to fit in the outer but someone managed to fit both outer pads on the same side!!
Caliper didn't fit very well and wasn't allowing the pads to release properly!!
Pads on this side were half worn compared to the other side which were like new, can see the gap between pad and caliper. Shocking.
Also a rarity for me, a mini!! 15 miles on the clock and it's broken down.
All that glitters isn't gold lol, it's main bearing shell/trust bearing. That much end float the crankshaft sensor no longer picks up the sensor wheel lol. Absolute crap and made out of chocolate I think!!!
One scrap engine!
Just for a change a timing chain guides that's fallen apart too! There's certain engines I wouldn't buy tbh as they're really not good!! Keeping me busy though lol
