- Jul 15, 2012
I think the lower caliper bolt is ceased and that I started to snap it off. Sprayed loads of wd40 and ordered some plus gas to try that as well. What is the best way to try and tackle this? So far my thoughts are:
- apply some heat to the bolt and spray with plus gas to try and get it to suck in
- hit hard on the top to try and knock/vibrate it loose.
What do you think the chance of me getting the bolt out without snapping it off? I've just bought centre punch, some HSS drill bits and some irwin spiral extractors, hoping I won't need to resort to these!
Also where is the best place to order small spares like new caliper bolts from?
Thanks,
Grant
Thanks,
Grant
