Hi,
A newbie here needing some advice with this broken ABS Sensor "casing?".
Can anyone recommend some products and the method to glue/bond this back together.
The sensor itself is fine, the casing broke when trying to undo the bolt (pictured) for the bracket which holds the wire connecting to the ABS plug.
I needed help from a dremel in the end to get the bolt and broken pieces free from the bracket holding the wire.
Any idea where I could get a hold of that nut.. do I need to replace this, old bolt screws in fine in current state.
Pics below:
Pics below:
