I have had a fluid leak for some months now . Level drops from max to below min over about 2 months. No obvious evidence where its from - is there a common failure point on the system?
It is most likely leaking from either the master cylinder under the bonnet or the slave cylinder bolted to the gearbox. Leaked fluid should be easily seen in those areas. Best way forward is to buy genuine Toyo replacement or the seal kit if the cylinder itself is in good condition and the kit available.
Check for fluid running down the clutch pedal from master and also in engine compartment.
