- Feb 24, 2010
Busy giving the 120 a new serpentine belt and new pink stuff. I drained the coolant from the drain valve at the bottom of the rad. For a few seconds it gushed out and then slowed to a trickle. The trickle has now stopped and all I have is about 5.5L - far from the 11.5 stated in the book. Before draining, the expansion bottle was on the min mark. Diff between min and max in the bottle cannot be more than one litre.
Am I missing something? I've jacked the back and then the front up to try and tip it out - no diff. Truck is on slightly level ground.
