Diff Actuator breather?
fridayman
Is there a breather hose that goes form the diff into a hole in one of the body spars? I have what looks like a hose that is taped to the diff lock wires - it used to plug into a hole in the body spar before the body lift, but is now just pointing into the air. If it is a breather, I can just plumb it into my breather setup.
Or what else can it be?
Yep. There is and yep, it just gets shoved into the chassis. There is also a diff lock breather that gets stuck into the cross member. I think that this is the one that you are talking about. It's very thin. The diff breather is a bit bigger.
So - 2 breathers both terminate pointlessly in the chassis.
Ok, thanks Chris. I'll just extend both into my new breather setup.
