Eish, what a night. Took quite some effort to get the front prop off given that the front steering parts are mangled. Luckily I'm weighing in at 70kgs now after too much cycling so operating anything heavier than a pencil is tough going.
So, front prop off. Check
Rear prop off. Check
Rear axle on stands (and later the chassis on the axle after much shoving, hitting hands, getting cut by broken glass and metal shards. oh joy it was tonight!)
Attached jumper leads to what looked like the right places
A quick call to Chris to make sure I hadn't attached the jumper leads to my ears and..
Nothing.
Argh.
So, I'm pretty sure first thing I am missing is 24V power. Of course my 2 multi meters are at home ie not where the truck is so I'll have to go back but before I do, some sanity checks please
1) This is the alternator as Dan pointed out.
2) The "positive and negative thick cable connector"
I'm trying to work out how to connect the jumper leads using what I have which is : a standalone starter battery and my truck with it's 2 starter batteries in the truck
Should I run the standalone linked to the other battery in my other red truck in series, then to one of the positive and negative terminals on the "positive and negative thick cable connector"?
Or? In my frustration I managed to rip one of the jumper lead connectors off. They're cheap so now i know how cheap looking at what must be 8mm cable if that
I plan on crimping the end to a crimp lug and bolting it straight on to ge a good connection
Ideas welcome..
5) The other side of the process. Stopping the engine.
I plan on letting the engine run on the fuel inside the fuel filter and recording it on my phone to show that it runs
Is it simpler to just let it run till the fuel in the diesel filter runs out given that it is detached from the fuel tank
or
I really need a backup plan to cut it out at a seconds notice
* the radiator is detached so it's running with no cooling (just the fan that'll be whizzing around)
No, I have no idea yet where the fuel solenoid is or what to do with it - do I need to?
Next step will be to get the engine, autobox and gearbox off the chassis so the chassi scan be cut up and removed
Any suggestions on order or dismantling? Assume :
- Unbolt engine mounts
- Lift using? engine crane?
- Cut up chassis
- Roll axles away
- Place engine on? Floor? Trolley?
Thanks for the help. It's been a bruising day! Going to lick my wounds..
