- Mar 1, 2010
Don't let the smoke out of the wires Chris. Toyota don't do replacement smoke.
Guys, not a hijack but a sort of side step. If you had a 12 set up and two batteries (well like a Collie for example) but wanted to run something that was 24volt, could you take a feed from both batteries (ie in series to give 24) to the device and earth to chassis? I get a bit misty here. Let's say it was a CB or something like that. I am guessing not, but curious as to where the volts would go. I suppose it would only be fed when switched on. Is there anyway to do this and say feed back to one or other earth terminal to prevent the current escaping?
Any mod to vehicle wiring has to be really thought through. The volts whether 12 or 24 may be low but the current they carry can run into thousands of amps! The low resistance in a battery means it could dump the whole lot in a few seconds into your vehicle wiring and a fire would be inevitable if you get it wrong. When looking for higher volts I would prefer an inverter for low current gadgets.
For something heavy like a winch I would either copy the LC 80 starter system in it's entirety or, (and this is my preference) install a completely independent 24v system. So that would be two batteries in series and a 24v volt alternator, twin alternators is not uncommon so should be workable? The advantage when winching is your vehicle electrics are under no strain at all, fire risk from an independent system (no change over relays/isolators and so forth) should be less. I have no doubt it could be done?
regards
Dave
I think you mean a converter and not an Inverter for low power gadgets Dave. An Inverter gives AC from DC.
Thanks for the correction, you are of course right, I had already edited my post to replace voltage with current so should have been on the ball and seen that cock up as well.
The 24v starter system components would handle the current for a winch OK IMO, subject to the duty cycle of the switchover relay being high enough. It's design intention is for relatively short engine starting/cranking events so prolonged use for other devices like winches could potentially overheat it. Some testing/experimentation of the unit would be required. JMO
I still have my old change over switch and when I get five minutes I will see if there are numbers/spec on it that might give us an idea, the only problem I see is if the engine is running that the alternator will be looking to charge a 12v source and the batteries will at time be in series so not sure about this, from a redundancy point of view I prefer a separate system.
regards
Dave
Just love the 80 in the winter, ploughing through 1m high banks of snow to nab a parking place, when all the others are slithering around virtually out of control.![]()
"-21C here New Year's Eve"
"hasn't risen above -8 since"
"-15 tonight"
"Too bloody cold to be standing around waiting for help to come"
"8 minutes for the temp gauge to get to normal from a -15C"
"whilst stood up overnight. At -30C"
"-40C and less"
"1m high banks of snow"![]()
Well I've enjoyed every word of this thread, and I feel like I know all about my 80 starting system (even though I don't really, but it was a good read!).
Anyway, it was -21C here New Year's Eve and it hasn't risen above -8 since. -15 tonight (again) and "getting colder" is the forecast. Touching wood, my truck has never given me starting problems, certainly nowt to do with 24V change-over haemeroids or whatever they are, and I'm glad of it.
Too bloody cold to be standing around waiting for help to come, so it's great to jump in the truck and have it start on a flick of the key.
BTW, I timed it at 8 minutes for the temp gauge to get to normal from a -15C start up at normal city running speed. I was impressed, and I've not had overheating problems either.
I've never felt I needed the rad blind, although it's in good nick and ready for action. Another use for the blind is to reduce the effects of wind blowing through the rad fins whilst stood up overnight. At -30C, it's reckoned that the rad cores can go down to -40C and less, with a stiff breeze blowing past the fins.
