[ELCO Digest]
Hi Al,
Maybe I should clarify that, like all indirect injection engines, when
you work them hard or turbo them aggressively they are very prone to
cylinder head failures. A friend went through two heads and 1 engine
rebuild with a properly setup turboed TD42. I told him to get a factory
turbo (direct injection) cruiser and he could not kill it. A friend ran
a matched pain in a tunnel boat one TD42T and one 1HD-T both set up the
same and three to four engine blowups later he found a second 1HD-T to
replace the nissan. The head eating mainly relates when turboed as in NZ
and Australia people seem to think by hanging a turbo on a patrol they
can have a landcruiser for a lot less money and it does not work that way.
Cheers,
Craig.
Al Hunter wrote:
Thanks Julian,
I was wrong, sorry, you sent me that for Tuesday 2nd. Hostonce
deleted that sent on the 1st. I have spoken to them as they left a
trace of it in their new spam catcher software. I naturally asked
them why they did it when I get one from the same address every day.
Though that has not stopped them bouncing them back to you. No
answer so far, so I would be grateful if you could send it again please.
Not got one for today (Thursday) yet @ 9.45 pm, but I guess there is
still time !
Jon
At 18:13 04/01/2007, you wrote:
Hi Jon,
I'll keep a close eye on future bounces and will send them through
again and let you know when they do bounce.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Id love to know the procedure for getting the aerial out, if you do a full
aerial strip Julian.
Mine has awful reception and doesn't fully retract so its time to swop out
If its easy ..........
Adrian
-----Original Message-----
Sent: 18 January 2007 18:00
Subject: [ELCO Digest]
** To reply to any of the messages below, create a new message and address
it to [Email address removed] and then copy across the subject line of the
message you are replying to - this will help to maintain the context and
threading. If you forget to do this you are less likely to receive a reply.
**=======================================================================Date: Thu, 18 Jan 2007 13:03:05 -0000
Subject: [ELCO] Replacing 80 series aerial insert
Reply-To: [Email address removed]
Hi,
Has anyone here replaced the aerial on their 80 with a new insert?
The ones I have done in the past had the aerial and then the plastic
tail, but the replacement I have is just the aerial with a screw thread
on the bottom.
I'm assuming I still have to go to the painful contortions to remove
the main aerial unit and then strip it to replace the aerial?
=======================================================================Subject: RE: [ELCO] Replacing 80 series aerial insert
Date: Thu, 18 Jan 2007 13:15:49 -0000
Julian
I too replaced a shaft, giving a purely manual aerial (until I drove
into some string stretched across the drive and broke it again)
buy too, which must be attached to the shaft and then fed into the motor
bit at the bottom of the hole. I'd be fascinated to learn how to do
this if you succeed...
Christopher Bell
|Hi,
|screw thread
|on the bottom.
ELCOInfo.html
Checked by AVG Free Edition.
Version: 7.5.432 / Virus Database: 268.17.0/639 - Release Date: 18/01/2007
18:47
Hi Adrian,
OK, will report back when done.
Repack with grease, not oil. Remember these are wheel bearings and need a very high viscosity compound to survive so check your bearings again. Make sure the dust seal and the sealing surface are absolutely dry when you install them otherwise you will attract dust and other debris that will dammage the seal and no need to chrome plate this surface unless you have very deep pockets, just give her a good rub as you did with emery. Just make sure you finish with a very fine grit.
Cheers,
mcb
----- Original Message -----
Date: Tuesday, January 30, 2007 7:00 pm
I ran 33x12=2E5s on 17x8 wheels with no lift and no rubbing=2E You can run 35s with a modest lift as I did later=2E BFG Mudterrains sound like the tire your looking for=2C but ofcourse there are many others that are good also=2E
mcb
From=3A elco-owner=40landcruisers=2Einfo (List Server)
Date=3A Tuesday=2C February 6=2C 2007 7=3A00 pm
Subject=3A =5BELCO Digest=5D
=3E ** To reply to any of the messages below=2C create a new message and =3E address it to elco=40landcruisers=2Einfo and then copy across the =3E subject line of the message you are replying to - this will help =3E to maintain the context and threading=2E If you forget to do this =3E you are less likely to receive a reply=2E =3E **=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3E From=3A =22Phil Stubbs=22 =3Cphil=40stubbsp=2Efsnet=2Eco=2Euk=3E
=3E Subject=3A =5BELCO=5D Hi there Tyres
=3E Date=3A Mon=2C 5 Feb 2007 22=3A16=3A41 -0000
=3E Reply-To=3A elco=40landcruisers=2Einfo
=3E Hi Just purchased a new set of Alloys for the 80 series =3E Landcruiser as the =3E old ones are all pitted and salt damaged=2E I was going to put the =3E tyres that =3E were on the wheels on the new alloys but now thinking about =3E changing to off =3E road tyres=2E I want some tyres that are 80=25 off road and 20=25 on =3E road=2E Can =3E anyone tell me what is the biggest size knobbly tyres you can fit =3E on to a =3E 16x8J Rim without any mods to suspension or bodywork=2E
=3E I know the standard size will be fine but wanted there to look =3E like there is =3E more rubber in the arches=2E
=3E I know guys on here talk about 31=27s etc and I=27m just not sure of =3E what is =3E right for the standard 80 Series Cruiser=2E
=3E Many thanks in advance=2E=2E=2E=2E
=3E =3E Please Help -
=3E =3E Cheers Phil
=3E Byfield OCPFUK =3E =3E =3E =3E =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3E =3E From=3A =22Chas=22 =3Cskypilot=40blueyonder=2Eco=2Euk=3E
=3E Subject=3A =5BELCO=5D Radio reset
=3E Date=3A Mon=2C 5 Feb 2007 23=3A03=3A50 -0000
=3E Hi Guys=2C
=3E I=27ve got home and as promised I went out to the LC to check on the =3E reset =3E button (hole) to set the radio back=2C it=27s a Sony WX-C570R double =3E din size =3E radio and the reset button (hole) is above and slightly to the =3E left of the =3E volume control knob=2E Hope that is of help=2C but as I said before it =3E may not =3E be a standard radio=2E
=3E TTFN
=3E Chas =3E =3E =3E =3E =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3E =3E Date=3A Tue=2C 06 Feb 2007 00=3A30=3A23 -0000
=3E Subject=3A Re=3A =5BELCO=5D Hi there Tyres
=3E From=3A Julian Voelcker =3Cjulian=40landcruisers=2Einfo=3E
=3E Hi Phil=2C
=3E =3E =3E I know guys on here talk about 31=27s etc and I=27m just not sure of =3E what is=EF=BF=BD
=3E =3E right for the standard 80 Series Cruiser=2E
=3E =3E =3EFrom memory you should be able to go up to a 285/75/16 without =3E any serious =3E rubbing=2E
=3E =3E Out of interest what sort of driving will you be doing - I find =3E mud tyres =3E on the 80 too much of a nightmare to use on the road=2C particularly =3E in the =3E wet or icey/snowy conditions that I will be glad to get shot of =3E the ones on =3E my 80 at the moment=2E
=3E =3E In your position I would be more inclined to stick some serious =3E mud tyres =3E on your old rims and then keep the nice shiney rims shod with ATs=2E=3E --
=3E Regards=2C
=3E =3E Julian Voelcker
=3E Mobile=3A 07971 540362
=3E Skype=3A julianvoelcker
=3E Cirencester=2C United Kingdom
=3E 1994 HDJ80=2C 2=2E5=22 OME Lift
=3E =3E Date=3A Mon=2C 05 Feb 2007 21=3A36=3A39 -0700
=3E From=3A Brendan Lally =3CBrendan=2ELally=40mail=2Ecom=3E
=3E I vote with Julian 4 a 2nd set of mud/more serious tires on old rims=2E
=3E then run AT=27s on the regular ones=2E
=3E =3E That=27s what I do and will continue 2 do so=2E
=3E I run 34=22 Simex Jungle Tracker II with 2=2E5=22 lift and great in mud =3E (not that I c any over here =3A) - 2 much snow !!!)
=3E =3E Lal with 96 fzj in Colorado
=3E =3E Julian Voelcker wrote=3A
=3E =3E Hi Phil=2C
=3E =3E =3E =3E=3E I know guys on here talk about 31=27s etc and I=27m just not sure =3E of what is =3E =3E=3E right for the standard 80 Series Cruiser=2E
=3E =3E =3E =3E=3EFrom memory you should be able to go up to a 285/75/16 without =3E any serious =3E =3E rubbing=2E
=3E =3E =3E =3E Out of interest what sort of driving will you be doing - I find =3E mud tyres =3E =3E on the 80 too much of a nightmare to use on the road=2C =3E particularly in the =3E =3E wet or icey/snowy conditions that I will be glad to get shot of =3E the ones on =3E =3E my 80 at the moment=2E
=3E =3E =3E =3E In your position I would be more inclined to stick some serious =3E mud tyres =3E =3E on your old rims and then keep the nice shiney rims shod with ATs=2E
=3E =3E --
=3E =3E Regards=2C
=3E =3E =3E =3E Julian =3E =3E --
=3E European Land Cruiser Owners Mailing List
=3E Further Info=3A http=3A//www=2Elandcruisers=2Einfo/lists/ELCOInfo=2Ehtml
=3E
Try OCE, UK TJM distributor. www.OCEinternational.com
Speak to Anton de Leeuw
Replies to [Email address removed]
> Subject: [ELCO Digest]> From: [Email address removed]> Date: Wed, 21 Feb 2007 18:28:43 +0000> > ** To reply to any of the messages below, create a new message and address it to [Email address removed] and then copy across the subject line of the message you are replying to - this will help to maintain the context and threading. If you forget to do this you are less likely to receive a reply. **=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Date: Tue, 20 Feb 2007 20:23:35 +0100> Subject: Re: [ELCO]> From: UHu <[Email address removed]>> Reply-To: [Email address removed]> Add an "i" somwhere close to the end of that long word in the link...> > > www.gonewanderng.co.uk> > > On Tue, 20 Feb 2007 18:42:27 +0100, Lubomir Kolev <[Email address removed]> > wrote:> > > Hi Jeff> > welcome back.....alive :-)> > looks exiting and looking forward to see and learn more about the trip > > but Windows explorer tells me .'can't open the page'> > Hhhhhhhhhhhhm> > cheers> > Lubo> > ----- Original Message ----- From: "jeff watts" <[Email address removed]>> > To: <[Email address removed]>> > Sent: Tuesday, February 20, 2007 2:09 PM> > Subject: [ELCO]> >> >> >> hi everyone> >>> -- > Ugo Hu, Oslo, Norway> HDJ100 AHC 2001, ex HZJ80> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: [Email address removed]> Date: Tue, 20 Feb 2007 14:32:13 EST> Subject: [ELCO] (no subject)> Reply-To: [Email address removed]> > -------------------------------1171999933> Content-Type: text/plain; charset=3D"US-ASCII"> Content-Transfer-Encoding: 7bit> > HI THER I WONDER IF ANY ONE CAN HELP IVRE BEEN TRYINIG TO GET A SNORKEL FOR > MY LJ70 BUT SAFARI DNT SEEM TO DO ONE CAN ANY ONE HELP PLEASE > > > P.EVANS > > > -------------------------------1171999933> Content-Type: text/html; charset=3D"US-ASCII"> Content-Transfer-Encoding: quoted-printable> > <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">> <HTML><HEAD>> <META http-equiv=3D3DContent-Type content=3D3D"text/html; charset=3D3DUS-ASCII">> <META content=3D3D"MSHTML 6.00.2900.3059" name=3D3DGENERATOR></HEAD>> <BODY id=3D3Drole_body=3D20> style=3D3D"FONT-SIZE: 10pt; COLOR: #000000; FONT-FAMILY: Rockwell Light"=3D20> bottomMargin=3D3D7 leftMargin=3D3D7 topMargin=3D3D7 rightMargin=3D3D7><FONT id=3D3Drol=3D> e_document=3D20> face=3D3D"Rockwell Light" color=3D3D#000000 size=3D3D2>> <DIV>HI THER I WONDER IF ANY ONE CAN HELP IVRE BEEN TRYINIG TO GET A SNORKEL=3D> FOR=3D20> MY LJ70 BUT SAFARI DNT SEEM TO DO ONE CAN ANY ONE HELP PLEASE </DIV>> <DIV> </DIV>> <DIV> </DIV>> <DIV>P.EVANS  </DIV></FONT> </BODY></HTML>> > -------------------------------1171999933--> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: Julian Voelcker <[Email address removed]>> Subject: RE: [ELCO] Gone wandering and now back!> Date: Tue, 20 Feb 2007 20:03:24 +0000> Reply-To: [Email address removed]> Yes, Jeff's website should be at http://www.gonewandering.co.uk> > CHeers,> > Julian=3D> > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: Julian Voelcker <[Email address removed]>> Subject: RE: [ELCO] 70 series snorkel> Date: Tue, 20 Feb 2007 20:03:28 +0000> Reply-To: [Email address removed]> Hi Philip,> > I am extremely surprised that Safari don't do a snorkel for your 70 series =3D> - who did you try and get one through?> > Have you tried people like TBR or Frogs Island - if available TBR should ha=3D> ve stock.> > P.S. When posting messages to the list, please try not to use capitals (Equ=3D> ivalent to shouting) and also provide a suitable subject line so that peopl=3D> e can see what the message is about before opening the message.> > Cheers,> > Julian=3D> > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Date: Wed, 21 Feb 2007 08:59:39 -0000> Subject: Re: [ELCO] 70 series snorkel> From: Julian Voelcker <[Email address removed]>> Reply-To: [Email address removed]> Actually I am pretty sure you should be able to get one from > http://www.tbruk.net/ - give them a call and ask for Trevor, very > helpful chap.> --> Regards,> > Julian Voelcker> Mobile: 07971 540362> Skype: julianvoelcker> Cirencester, United Kingdom> 1994 HDJ80, 2.5" OME Lift> > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: "Lubomir Kolev" <[Email address removed]>> Subject: Re: [ELCO]> Date: Wed, 21 Feb 2007 09:28:56 +0100> Reply-To: [Email address removed]> that's what I get clicking the link below:> Internet Explorer cannot display the webpage> > > Cheers> Lubo> > ----- Original Message ----- > From: "UHu" <[Email address removed]>> To: <[Email address removed]>> Sent: Tuesday, February 20, 2007 8:23 PM> Subject: Re: [ELCO]> > > > Add an "i" somwhere close to the end of that long word in the link...> >> >> > www.gonewanderng.co.uk> >> >> > On Tue, 20 Feb 2007 18:42:27 +0100, Lubomir Kolev <[Email address removed]> > > wrote:> >> >> Hi Jeff> >> welcome back.....alive :-)> >> looks exiting and looking forward to see and learn more about the trip > >> but Windows explorer tells me .'can't open the page'> >> Hhhhhhhhhhhhm> >> cheers> >> Lubo> >> ----- Original Message ----- From: "jeff watts" <[Email address removed]>> >> To: <[Email address removed]>> >> Sent: Tuesday, February 20, 2007 2:09 PM> >> Subject: [ELCO]> >>> >>> >>> hi everyone> >>>> > -- > > Ugo Hu, Oslo, Norway> > HDJ100 AHC 2001, ex HZJ80> > --> > European Land Cruiser Owners Mailing List> > Further Info: http://www.landcruisers.info/lists/> >> >> > -- > > No virus found in this incoming message.> > Checked by AVG Free Edition.> > Version: 7.5.441 / Virus Database: 268.18.3/694 - Release Date: 2/20/2007 > > 1:44 PM> >> > > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: "John Byrne" <[Email address removed]>> Subject: [ELCO] bio diesel> Date: Wed, 21 Feb 2007 14:48:17 -0000> Reply-To: [Email address removed]> Hi Julian> Seeing as how you have been using the biodiesel for a whikle now have you > come across any problems with fuel filters etc.> I ask because I remember you saying that the biodiesel will actually clean > out pipes a little.> But I came across an article about problems with biodiesel and bacteria > building up in the filters and pipes.> A city in the states has suspended the use of the biodiesel in its fleet of > trucks because of breakdowns relating to the bacteria.> Is it a case that you will soon be bringing the cruiser for a trip to the > Doc for a prescription for antibiotics to be taken three times daily.> cheers> john 92HDJ 80 1HDT > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: "Malcolm Bagley" <[Email address removed]>> Subject: RE: [ELCO] bio diesel> Date: Wed, 21 Feb 2007 14:52:28 -0000> Reply-To: [Email address removed]> Does this also preclude vegans from using biodiesel?> > Malcolm Bagley> Stafford, UK> 1975 FJ45 Pickup (in work)> 1976 FJ45 Pickup (next one)> _______________________________> > > -----Original Message-----> From: [Email address removed] [mailto:[Email address removed]] On> Behalf Of John Byrne> Sent: 21 February 2007 14:48> To: [Email address removed]> Subject: [ELCO] bio diesel> > Hi Julian> Seeing as how you have been using the biodiesel for a whikle now have you > come across any problems with fuel filters etc.> I ask because I remember you saying that the biodiesel will actually clean > out pipes a little.> But I came across an article about problems with biodiesel and bacteria > building up in the filters and pipes.> A city in the states has suspended the use of the biodiesel in its fleet of > trucks because of breakdowns relating to the bacteria.> Is it a case that you will soon be bringing the cruiser for a trip to the > Doc for a prescription for antibiotics to be taken three times daily.> cheers> john 92HDJ 80 1HDT > > --> European Land Cruiser Owners Mailing List> Further Info: http://www.landcruisers.info/lists/> > -- > No virus found in this incoming message.> Checked by AVG Free Edition.> Version: 7.5.441 / Virus Database: 268.18.3/694 - Release Date: 20/02/2007> 13:44> > > -- > No virus found in this outgoing message.> Checked by AVG Free Edition.> Version: 7.5.441 / Virus Database: 268.18.3/694 - Release Date: 20/02/2007> 13:44> > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: "Martin Naylor" <[Email address removed]>> Subject: RE: [ELCO] 70 series snorkel> Date: Wed, 21 Feb 2007 15:06:45 -0000> Reply-To: [Email address removed]> Hi,> Missed the original message for some reason, I got my snorkel from frog> island 4x4. Believe it was for a HZJ75 (PICKUP?), fitted on my kzj70 no> problems. The only thing I would watch out for is what is your 70 series?> Does the air intake go into the side of the wing or is at the front near the> radiator, is its in the wing then all should be ok, you will probably need> to scrap the parts for air filter box and use you own bit of pipe(3") to> connect the snorkel to the air box.> > > Regards> > Martin.> > > > > > -----Original Message-----> > From: [Email address removed] [mailto:[Email address removed]]> > On Behalf Of Julian Voelcker> > Sent: 21 February 2007 09:00> > To: [Email address removed]> > Subject: Re: [ELCO] 70 series snorkel> > > > Actually I am pretty sure you should be able to get one from> > http://www.tbruk.net/ - give them a call and ask for Trevor, very> > helpful chap.> > --> > -- > No virus found in this outgoing message.> Checked by AVG Free Edition.> Version: 7.5.441 / Virus Database: 268.18.3/694 - Release Date: 20/02/2007> 13:44> > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: "Martin Naylor" <[Email address removed]>> Subject: [ELCO] 70 series gearbox woes :(> Date: Wed, 21 Feb 2007 15:06:45 -0000> Reply-To: [Email address removed]> Hi,> I am having some bearing (humming noise) that appears to becoming from the> gearbox, whilst in 3rd, 4th, and 5th gear.> The noise get proggresivly worse the faster you go, its definlty coming from> the gear box area, and gets more noticeable once vehicle/gearbox has warmed> up.> Has anyone had anything similair happen?> Could it be related to the clutch as this appears to be on the way out as> well?> Before dismantling the box has anyone got any suggestions?> The noise disappears if I lift my foot of the throttle or put the clutch in,> and only becomes noisy when in 3rd and above.> > Thanks in advance.> > Martin.> > > -- > No virus found in this outgoing message.> Checked by AVG Free Edition.> Version: 7.5.441 / Virus Database: 268.18.3/694 - Release Date: 20/02/2007> 13:44> > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Subject: RE: [ELCO] bio diesel> Date: Wed, 21 Feb 2007 15:53:07 -0000> From: "Christopher Bell" <[Email address removed]>> Reply-To: [Email address removed]> Malcolm> > No, only from drinking it ...> > Christopher Bell=3D20> |> |Does this also preclude vegans from using biodiesel?> |> |Malcolm Bagley> ____________________________________________________________> Electronic mail messages entering and leaving Arup business> systems are scanned for acceptability of content and viruses> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Date: Wed, 21 Feb 2007 10:58:05 -0500> From: "Niall Sommers" <[Email address removed]>> Subject: RE: [ELCO] bio diesel> Reply-To: [Email address removed]> This is a MIME message. If you are reading this text, you may want to > consider changing to a mail reader or gateway that understands how to > properly handle MIME multipart messages.> > --=3D__Part80A4141D.0__=3D> Content-Type: text/plain; charset=3DUS-ASCII> Content-Transfer-Encoding: quoted-printable> > Christopher / Malcolm> =3D20> Re vegans & biodiesel> =3D20> Think they can still drink it - just has to carry a health warning....> =3D20> Niall> > > --=3D__Part80A4141D.0__=3D> Content-Type: text/html; charset=3DUS-ASCII> Content-Transfer-Encoding: quoted-printable> Content-Description: HTML> > <HTML><HEAD>> <META http-equiv=3D3DContent-Type content=3D3D"text/html; charset=3D3Diso-8859-1"=3D> >> <META content=3D3D"MSHTML 6.00.2800.1561" name=3D3DGENERATOR></HEAD>> <BODY style=3D3D"MARGIN: 4px 4px 1px; FONT: 10pt Tahoma">> <DIV>Christopher / Malcolm</DIV>> <DIV> </DIV>> <DIV>Re vegans & biodiesel</DIV>> <DIV> </DIV>> <DIV>Think they can still drink it - just has to carry a health =3D> warning....</DIV>> <DIV> </DIV>> <DIV>Niall
</DIV></BODY></HTML>> > --=3D__Part80A4141D.0__=3D--> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > From: "John Byrne" <[Email address removed]>> Subject: [ELCO] timing belt service> Date: Wed, 21 Feb 2007 16:11:48 -0000> Reply-To: [Email address removed]> Hi Guys> I was just wondering is there a set number of times after which it is > adviceable to replace the tensioner when replacing the belt.> I ask because mine is nearly due a belt but after the last mishap of being > within a few miles of messing upthe engine because of so called metal > fatique in the tensioner.> This broke and the belt ate its way through the cover.> cheers> john 92HDJ 80 1HDT > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Subject: RE: [ELCO] timing belt service> Date: Wed, 21 Feb 2007 16:27:57 -0000> From: "Christopher Bell" <[Email address removed]>> Reply-To: [Email address removed]> John> > |I was just wondering is there a set number of times after which it is=3D20> |adviceable to replace the tensioner when replacing the belt.> |I ask because mine is nearly due a belt but after the last mishap of> being=3D20> |within a few miles of messing upthe engine because of so called metal> > |fatique in the tensioner.> |This broke and the belt ate its way through the cover.> > > Last time my timing belt was changed was at 120k miles, ie its second> change, and I decided to replace the roller and tensioner as a> preventative measure. There were no symptoms of any problems, I was> just being a nervous nellie.> > We had to get the bits from Toyota: they do not come as a kit and, so> far as we could make out, there was no specified schedule for replacing> them. The Toyota agent's attitude was "inspect and replace if worn".=3D20> > > My mechanic's comment when we were having a look at the old bits> afterwards was "well, these look absolutely fine", and to my eyes and> ears they were; but in addition he pointed out that if I trashed the> engine it would probably cost more than the vehicle is worth to fix it.> > In short he didn't call me an old woman (to my face) but sort of implied> that I was a middle-aged one!> > For your info the costs of the parts on 21/3/06 were (Pounds sterling,> excluding VAT)> > Timing belt: 27.80> Tensioner: 43.16> Idler: 96.23> > That's all I know!> > Christopher Bell> Devon, UK> 1996 1HD-FT> ____________________________________________________________> Electronic mail messages entering and leaving Arup business> systems are scanned for acceptability of content and viruses> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Date: Wed, 21 Feb 2007 17:18:33 -0000 (UTC)> Subject: Re: [ELCO] timing belt service> From: "Jon Wildsmith" <[Email address removed]>> Reply-To: [Email address removed]> > > I was just wondering is there a set number of times after which it is> > adviceable to replace the tensioner when replacing the belt.> > Not really. Last time the timing belt was changed on my 94 (120k) the> tensioner bearings were rough so I changed it. Last time the belt was> changed on Stephs 93 (120k) the tensioner was fine so it stayed on.> > Milner do sell the (genuine Toyota) tensioners and I seem to remember they> are cheaper than a dealer.> > Regards,> Jon.> 93&94 HDJ80's.> UK.> > P.S. I have a spare brand new tensioner for a 24 valve if anyone needs one.> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> > Date: Wed, 21 Feb 2007 17:30:43 -0000> Subject: Re: [ELCO] bio diesel> From: Julian Voelcker <[Email address removed]>> Reply-To: [Email address removed]> Hi John,> > > Seeing as how you have been using the biodiesel for a whikle now have you > > come across any problems with fuel filters etc.> > I found that the biodiesel cleaned the crap out of my system which blocked > the fuel filter, but after a couple of tanks full it was all OK.> > You can get problems with deposits building up in the fuel filter due to it > being very cold or a bad batch of fuel, but that comes down the the > supplier.> > The only thing I have had to do a couple of times is drain the some water > out of the bottom.> --> Regards,> > Julian Voelcker> Mobile: 07971 540362> Skype: julianvoelcker> Cirencester, United Kingdom> 1994 HDJ80, 2.5" OME Lift> > > --> European Land Cruiser Owners Mailing List> Further Info: http://www.landcruisers.info/lists/ELCOInfo.html
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=3Dwindows+vista&mkt=3Den-US&form=3DQBRE
Hi Gurvir,
When replying to messages in the digest, please do not copy the whole
of the digest in the bottom of your message.
For full details on the best way to post messages please read:
http://www.landcruisers.info/lists/list_rules.html
Count me in for the 25th please !
Best
Adrian
From: [Email address removed] [mailto:[Email address removed]] Sent: 25 February 2007 18:29
Subject: RE: [ELCO] 70 series gearbox woes :(
Date: Sun, 25 Feb 2007 09:32:14 -0000
Hi Dennis,
Thanks for the information, that=3D92s defintly worth thinking about doing
depending on what's wrong with mine, hopefully I can have a look next
weekend.
Thanks again.
Martin.
_________________________________________________________________________=3D
_
21/02/2007
21/02/2007
--=3D20
Version: 7.5.441 / Virus Database: 268.18.3/699 - Release Date: =3D
23/02/2007
13:26
=3D20
Date: Sun, 25 Feb 2007 10:04:48 -0000
Subject: [ELCO] [ADMIN] Possible Salisbury Plain trip - 25th March 2007
Hi,
I'm toying with the idea of organising another Salisbury Plain trip on
the Sunday 25th March.
I need to check with the MOD and the Bustard first, but will do that
this week.
The trip is long overdue, however all being well I'll be leaving for
Morocco the following Saturday and it will give me a good chance to
shake down the car, however if I'm running out of time to get
organised I may need to drop out at the last minute and leave someone
else in charge of organising things on the day.
So, please could you reply to this message if you are interested in
coming along.
Also, please could you let me know if....
(a) you are willing to lead a group of around 5 other cars around. I
have a number of routes pre plotted that I can hand out, although some
sort of Satnav system will help (all the routes I have are plotted on
Memory Map)
(b) you are willing to take over the organising on the day - mainly
just ticking off names on lists, making sure people get into the right
groups and then making sure that lunch is paid for.
As with the last trips the main emphasis is a friendly family day out
to get people together and put faces to names.
None of the tracks around the plain can be classified as challenging,
but if the rain keeps up there will likely be a fair bit of mud around.
For those that haven't been before we try to meet up down on the plain
around 8.30am, spend the morning driving the local tracks and then
retire to Bustard inn for lunch and then afterwards you can either stay
at the pub and admire each others cars or take off again for some more
fun and frolics in the mud.
On the costs front the lunch is generally around =A38-9 per head and then
I try to take donations for the organisation of the day (around =A310 per
vehicle), with the funds paying for the group leader's lunches and then
the remaining going to a local charity.
I look forward to hearing from you.
Date: Sun, 25 Feb 2007 10:04:52 -0000
Subject: [ELCO] [ADMIN] Newbie Intros
Hi,
I have noticed a number of people joining the list in the last couple
of weeks.
When you have a moment, please take the time to post a brief intro
message to the list, it is always nice to know who is out there.
Also, before you post, please take a moment to read the list rules at
http://www.landcruisers.info/lists/list_rules.html - they are pretty
straight forward and adhering to them just makes life easier for the
rest of us.
Thanks.
Happy Posting!
Subject: RE: [ELCO] [ADMIN] Possible Salisbury Plain trip - 25th March 2007
Date: Sun, 25 Feb 2007 18:21:27 -0000
Hi Julian,
Please count me in. I've still got a set of stock springs and shocks put by
for you, so if you still want them I'll bring them on the day.
Toby
1990 HDJ80 UK
=09
Inbox full of spam? Get leading spam protection and 1GB storage with All New
Yahoo! Mail. http://uk.docs.yahoo.com/nowyoucan.html
ELCOInfo.html
Internal Virus Database is out-of-date.
Version: 7.5.441 / Virus Database: 268.17.39/687 - Release Date: 14/02/2007
16:17
my vehicle has an ETA felixtowe for the 23rd if i can get it id love to
come
regards
jeff
Upload 500 photos a month & blog with your Messenger buddies on Windows Live
Spaces. Get yours now, FREE! http://specials.uk.msn.com/spaces/default.aspx
Great that you two can come along, however please remember that when
replying to messages in the digest, create a new message to the list
and then copy across the subject line and add your message.
You will both suffer tomorrow when you end up with triplicate messages
in the Digest ;-) although so will everyone else on the digest !
Hi Bill
I'm glat Maarten managed to help you out - was wondering how you were getting
on.
Hi William
I already did change the turbo :-)
as I posted yesterday I'll keep the car whatever it might cost me and the
near plan is to drive down to Bulgaria on a
holyday and there to repair the rest!!!!!!!! I have already contacted Toyota
at the resort I used to stay and they are prepared to take the beauty and
fix it. By the way the hour labour there is 10?, but the cost for the spare
parts is like here...
Little bit scared but now in Bulgaria you can find more Cruisers than in
Norway -hehehehe( and many other cars like Ferrari,
Lamborghini and stuff like that you seldom see anywhere else.But the
ex-communists are now-capitalists and despite the short live they live
today(too much order killings) they live it GOOD!!!!
cheers
Lubo
Hi Phil
is that a price for original Toyota SS exhaust?
rgrds
Lubo
Hi there Lubo, The price quoted was for the standard Mild steel exhaust!
That was through a exhaust fitting centre! I know the guy in there and they
get a good discount from Toyota OEM parts. That was the cost supplied to
them with their 40% discount. The guy in the exhaust fitting place said if
it was anyone else he would add 60% to the cost of the Toyota part and sell
it to joe public for ?1262.40 Fitted.
Milners have called today and said that they cannot supply an exhaust for
the 4.5 petrol varient. Main Dealer only!!!
So I have emailed about the top 15 SS Exhaust makers today and asked if
they make the parts off the shelf. If not why not and what they are going to
do to help us out.
I have taken my 4.5 to the place in sheffield ASCAR and Powerflow in
Leamington for a quote today. I will update asap when they give me a price.
You can get the system cheaper if you opt for a side exit exhaust just under
the side steps as it cuts down on the construction. But if you want a copy
part then it looks like its going to be ?750+
On a totally different subject - anyone know if Procomp do a suspension
system for the 4.5 80 series. Either replacement or 2-3" lift??
Thanks in advance to all
Phil Stubbs
OCPFUK
97 - FZJ80 Gunmetal and chrome
BYFIELD SJ
Hi Lubo,
I don't think that Toyota ever supplied a SS exhaust.
Hi there Julian - I have a full set that i have taken off my 80 series -
they are the usual salt damaged set but - if you interested make me an
offer. They are with the nuts and centre caps. Not sure if thats any good or
were you looking for a free single wheel?
Phil Stubbs
OCPFUK
BYFIELD SJ
Hi All I want to add a second battery to my LC - a UK made FJ80 petrol 4.5.
I need to move the water res and bolt in a new tray... but what's the
cheapest way to do this ?, anyone have a tray or conversion kit for sale ?
If not where should I go to get the parts ?... any breakers specialise in
LC's ?
Adrian
From: [Email address removed] [mailto:[Email address removed]] Sent: 26 March 2007 18:02
Subject: RE: [ELCO] Tales from the Workshop Part 3
Date: Sun, 25 Mar 2007 20:47:45 +0000
Hi Jon,
I guess all in all the BEBs tage around 4 hrs to do.
The longest part is removing the pan and then cleaning the old seal from th=3D
e block and pan.
To remove the pan I wedged one corner and then pried it off - it did bend u=3D
p the corner a bit, but was easy to straighten.
You can get a knife or scaper and then wedge it in and knock it around cutt=3D
ing the seal, but with the axle, etc in the way you don't have much space t=3D
o swing the hammer.
I used a sharp knife to slice off as much as possible of the old seal and t=3D
hen used a wire brush on a drill to clear off the rest. Afterwards I clean=3D
ed the whole thing in the parts cleaner to clean off any remaining crap.
You could do it without jacking the car up, but jacking it helps because yo=3D
u need to slide in and out under the axle several times - I have the axle o=3D
n axle stands - in hindsight I would jack the body up onto axle stands to g=3D
ive more space between the axle and the pan.
The bolts have a star/splined head with 12 points - you could order the SST=3D
, however I bought a set of standard Draper sockets that acts on the corner=3D
s of bolts as opposed to the flats like more 'modern' sockets that work on =3D
the flat sides - these sockets are the required star shape and have done th=3D
e job.
There aren't any tabs on the bolts - you can either tighten them to 27ft lb=3D
s and then turn another 180 degrees or just tighten to 68ft lbs (depending =3D
on the manual you use).
You should check the bolt lengths to see if they have stretched before re-u=3D
sing - I re-used mine this time around since they were in spec, but next ti=3D
me would probably replace them - it provides more confidence when torquing =3D
up.
As for turning the engine over, it easier with the injectors out, but could=3D
be done with them still in - I have an old torque wrench that I use as a s=3D
tandard socket wrench - the extra length gives more leverage and control.
I hope that helps.
Cheers,
Julian =3D
Date: Mon, 26 Mar 2007 01:25:08 +0100
Subject: RE: [ELCO] Hdj73
Kirk wrote...
Thanks to Jon from Tring for info. on swb 4.2. I have since found out
that Yoyota did put a 4.2 turbo in a swb and called it a hdj73.
Sounds like it would be terrific off-road with the power and short
overhangs.Ayone know where I could get one? Thanks to Julian for
keeping us posted on his major service, I for one am finding it very
interesting. Keep it up.
SNIP
Kirk, pleased that between us we could help, its why Julian got us
all together after all. Its interesting that you found out that they
put the 4.2 turbo in the SWB so I think we would all like to know
which version they used - the 12 or 24valve model, its seems unusual.
As for getting hold of one. Keep Googling for dispersal sales etc.
thoughout Europe. I can't see you would get a RHD one but possible to
get LHD from an aid agency dispersal where they are working in the
Balkans from Romania down to Turkey. Also look for UN dispersals from
Kosovo ( known as 'UNMIK'). Also input the names of familiar
charities etc with the phrase surplus vehicle dispersal and see what
comes up. Some charities retrieve their vehicles to European depots
before disposing of them. The Red Cross (ICRC) also hold a lot of
Toys and have a massive depot in Belgrade, don't forget they may be
listed under 'red crystal' now.
Maarten at AAI is always on the look-out for, and sells, odd models
like this and he may be worth a call. He comes to me for help with
anything he hears of in the Balkans. Last time it was single cab
dropside pick-up 70's in desert camo !
As for finding out more about the variants - and this may interest
Phil and his 70 series too - look first at ....
http://rustybrain.com/cruisers/faq.txt
This is a legendary history of the marque and runs to about 350k.
It was later updated as ....
http://www.cruiserfaq.com/00-01.html
But I am told that it is worth reading and comparing the two versions
side by side, though I don't know what the variation between them is. HTH
Jon
Tring,Herts
Subject: [ELCO] connection of spots
Date: Mon, 26 Mar 2007 11:12:10 +0100
Hi Guys
I was just wondering if anyone knows what the headlight relay in the black
box on the passenger side in the engine bay would be capable of
withstanding.
Could you connect spots to this relay or would that over power it or blow
it.
john 92HDJ 80 1HDT
Subject: [ELCO] cargo net
Date: Mon, 26 Mar 2007 11:17:26 +0100
Hi guys
I would like to know where to get my hands on a stretchy cargo net to hold
stuff in the boot of the cruiser.
I tried Machinemart but the gaps in the netting are 6 inches which are too
large, also they want =A318 just for delivery.
I am after a net that can be stretchy and have small holes say about 2
inches square, any ideas.
thanks
john 92HDJ 80 1HDT
Date: Mon, 26 Mar 2007 11:27:23 +0100
Subject: Re: [ELCO] connection of spots
John,
That relay or two relays (in case of dim/dip setup) are hardly good
enough for OEM headlamps.
Haven't you had problems with the lights in the past because of the
relay getting hot and failing?
You'll need a separate power relay for the spots, rated at least 40A.
Rgds,
Roman (London, UK)
'92 HDJ80
On 3/26/07, John Byrne <[Email address removed]> wrote:
black
blow
ELCOInfo.html
